wmonk
Joined: Sep 15, 2008 Posts: 504 Location: Enschede, the Netherlands
Audio files: 566
Joined: Mar 11, 2014 Posts: 456 Location: New Zealand
Audio files: 29
Posted: Mon Jan 15, 2018 9:43 pm Post subject:
Always feels good to wrap up a longrunning project. I've had this on the backburner for a couple years now -- while the panel says 2018, the back of the pcb says 2016 Catgirlsynth Stomp Box Adaptor.
Yusynth Comparator. With how well the CGS60 panel turned out (I tried ordering aluminium for the material, rather than the usual FR4 pcb material), I kinda wish I'd ordered this and the sequencer in aluminium too. Forgot the bypass caps on the PCB... eh, I can patch them in on the back if I find they need it. |
Audio files: 29
Posted: Fri Jan 19, 2018 1:37 pm Post subject:
Right. So, I've had this on the backburner for awhile, and electrically, it's all sorted. The toggle switches I used, however, are cheap and do not match the pots' height. Plus the panel is a trifle too short, and two mounting holes don't match. Quibbles! (Although I may well do a new panel!)
Joined: Jan 07, 2009 Posts: 1069 Location: Scottish Borders
Audio files: 131
Audio files: 131
LFLab
Joined: Dec 17, 2009 Posts: 458 Location: Rosmalen, Netherlands
Posted: Mon Jan 22, 2018 3:41 am Post subject:
AlanP wrote: |
Nice, the wiring on the original is mindboggling indeed, good way to simplify.
With respect to the switches, there's a Tyco switch which is small enough, the APEM TL series will work, and Thonk has submini switches with a height which matches 9mm Alpha and PC mount jacks. All of 'm are a lot more expensive than the "el-cheapo Chinese" SPDT's though. |
Audio files: 566
jh
Joined: Apr 03, 2004 Posts: 22431 Location: The Netherlands, Enschede
Audio files: 216
G2 patch files: 319
Posted: Sun Jan 28, 2018 9:14 am Post subject:
What a lovely lil big synth - do you have any details on it? _________________ Jan |
jh
Posted: Sun Jan 28, 2018 11:48 am Post subject:
Thanks for your interest.
13 voices, 13 voice polyphony. Same functions per key.
Select waveform from ; sine,tri,sqr,saw,pulse,pwm
Pulse adjustable, (positive period from 0...50%)
PWM speed control, pulse width control
12 db/octave filters, lp/hp/bp, Q value adjustable
Cutoff control with lfo / pot.
Blue Hell wrote: | What a lovely lil big synth - do you have any details on it? |
Audio files: 29
Posted: Sun Jan 28, 2018 7:08 pm Post subject:
WOW that is impressive!
What do the guts of it look like?  |
Joined: Nov 23, 2015 Posts: 686 Location: Netherlands
Audio files: 20
Posted: Mon Jan 29, 2018 12:54 am Post subject:
And more important: How does it sound?  _________________ my synth |
jh
Posted: Mon Jan 29, 2018 4:07 am Post subject:
AlanP wrote: | WOW that is impressive!
Thanks.
Inside is some 200 meter of wire and casual pcb's, comparators, integrators, inverting and non inverting op amp's. Sorry, don't have picture and dare not to open hood, because prototype tends to have new faults every time the hood is open. Last edited by jh on Fri Feb 09, 2018 1:36 am; edited 1 time in total |
LFLab
Posted: Wed Jan 31, 2018 1:29 am Post subject:
Well, you can post your thesis here, I assume it has some more info?
What are you studying? |
kaputtpanzer
Audio files: 566
Posted: Sat Feb 03, 2018 11:38 am Post subject:
doesn't matter how it looks as long as it is useful
I have thought about making something like that many times before and I think I even have a list of things I wanted to incorporate.
Someday, someday,..  _________________ "My perf, it's full of holes!"
SoundCloud BandCamp AcidTrasH Stickney Synthyards |
kaputtpanzer
Posted: Sat Feb 03, 2018 11:43 am Post subject:
Hey Phobos, took me around 5 years to finally built this. It was finished in a few hours and it is totally worth it... |
Broadwave
Joined: Feb 16, 2007 Posts: 346 Location: Manchester UK
Audio files: 6
Posted: Thu Feb 08, 2018 2:52 am Post subject:
Just on the final leg of another Minimoog Clone - This one is built from the Guin Guin MME kit, and sounds amazingly like a genuine Minimoog (no reason why it shouldn't - same circuit to the 3046 VCO version), and still cheaper than hacking the Behringer D.
Edit - March 19th. Finished the 5 week build
 _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings Last edited by Broadwave on Mon Mar 19, 2018 1:19 am; edited 2 times in total |
Audio files: 216
G2 patch files: 319
Posted: Sat Feb 24, 2018 3:43 am Post subject:
never relalized that the appendage was that big and the pcb was that well stuffed.
It all works? or don't know yet? _________________ Jan |
Posted: Sat Feb 24, 2018 8:25 am Post subject:
I have not wired it up to any of the external controls, or the actual softpot, so no idea  |
Audio files: 29
Posted: Fri Apr 06, 2018 12:17 pm Post subject:
962 style sequential switch Trigger in, out, and pushbutton per stage  |
Audio files: 566
stolenfat
Joined: Apr 17, 2008 Posts: 460 Location: Sunny Oakland California
