 Forum index » Clavia Nord Modular » Bugs
SeqCtr bug
Page 1 of 1 [3 Posts]
Rivelen
G2 patch files: 12
PostPosted: Wed Aug 29, 2007 6:06 am    Post subject: SeqCtr bug
Subject description: output modified by slider not currently selected (xfade off)
I haven't seen this in the bug report :
in the SeqCtrl, when you change the value of the right slider from the select one, it modify the output (of course xfade is off).
An example: the seqctr out is currently positionned on the slider 1,
if you move the slider 2, when its value reach the slider 1 value, the output value is increased by 1.
I don't know if it is very clear, so i send an example patch.
(g2 os 1.4, osX 10.4.10)
sqCtrl bug.pch2
 Filename:  sqCtrl bug.pch2
 Filesize:  1.17 KB
 Downloaded:  1064 Time(s)
G2 patch files: 625
PostPosted: Wed Aug 29, 2007 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked confirmed
Electromagnetic Wave
G2 patch files: 37
PostPosted: Tue Feb 06, 2018 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found a way to "fix" it by inserting another seq module before. The value from the other seq can be set at 64 (bipolar) or 1(unipolar). These values have no effets on the other sequencer (altering the sum from the 2 sequencers). Just be sure to use the same mode uni/bi polar on the 2 sequencers.
Here is an exemple
.... how I changed the world by finding a solution to the SeqCtr bug thumright
sqctrl_bug_153Fixv11.pch2
Fix the sqctrl_bug_153 by inserting another sequencer before
 Filename:  sqctrl_bug_153Fixv11.pch2
 Filesize:  1.7 KB
 Downloaded:  561 Time(s)
