Yusynth Steiner Filter stomp box - 50Hz Hum issue
Page 1 of 1 [10 Posts]
lebarde
PostPosted: Tue Feb 06, 2018 1:39 pm    Post subject: Yusynth Steiner Filter stomp box - 50Hz Hum issue Reply with quote  Mark this post and the followings unread
Hey Guys,
I've built a unit featuring two parallel Steiner filters provided by Yves.
Just tested the thing today and it sounds amazing !!
I wanted something like this for years and I so happy I did it, being able to run anything through a nice analog filter in stereo.
I know some products like this exist, but not so much actually.
I'm just having an issue having a hum noise at the usual 50Hz. It's not crazy loud but still too loud. I'm wondering if it comes from the power supply itself not being good enough, I choose something quite decent though.
Would anyone here be kind enough to help me trouble shoot that ?
 Filesize:  2.44 MB
 Viewed:  182 Time(s)
 Filesize:  2.98 MB
 Viewed:  163 Time(s)
 Filesize:  1.81 MB
 Viewed:  155 Time(s)
Audio files: 230
G2 patch files: 319
PostPosted: Tue Feb 06, 2018 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd first try to move the power supply out of the box for a test to see if it is that.
Nice box BTW:-)
g.gabba
PostPosted: Tue Feb 06, 2018 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice box!
some guys on the other side of the wormhole had recently a similar discussion
may it worth a look?
http://www.muffwiggler.com/forum/topic-194002.html&sid=90284ee924628362a5a38e6cdb270963
and of course moving the power supply out of the box would be my first test to
lebarde
PostPosted: Wed Feb 07, 2018 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your answers.
Good call trying to put the power supply out of the box.
Just tried, it does improve the issue by about 10db already.
I was keen having the DC adapter in the box though.
Cheers for the other topic link, will try what they did there and report.
wackelpeter
Audio files: 10
PostPosted: Fri Feb 09, 2018 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
For your own safety take the PSU out of the box. It's absolutely dangerous with your metallic front plate and having it not grounded with mains earth.
What i also see as very critical/crucial for your safety is that there seems to be no strain relief on the mains cable, means if you pull hard enough perhaps the mains wire get loose and come in contact with the metal case.
Also a fusing the primary side should be included.
Really, for your own safety reasons consider to re-arrange that part.
edit: okay see your using a socket for your mains... this would make the strain relief unnecessary.
yusynth
PostPosted: Thu Feb 15, 2018 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
You would also gain to use shielded wire for the audio connections (inputs and outputs and also for the connection to the rotary switch.
Yves
lebarde
PostPosted: Fri May 17, 2019 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys,
Back here for this topic.
Took me ages to go ahead with this issue, but constantly tried to do a few tests every now and then. Thanks again for your previews messages and ideas.
As said moving the PSU out of the box wasn't miraculous.
Today, exploring some more and I was thinking that it could come from the wooden box doing some sort of antenna thing with the circuit compared to a metallic box where everything is more isolated from electro magnetism.
When I was moving the box away from the desk it was changing the level of the hum by a lot.. more than just shaking the cables around.
Finally, before putting all in a metallic box, I just put an aluminium plate under the box and wired it to the ground... bam, 100% of the hum gone !! me happy Smile
So definitely going to do that, put the aluminium plate inside under the circuits and wired to the ground.
However, I still have a problem with this filter and I'd love to have your inputs.
When I tweak the cutoff knob, I have a serious level of almost DC value.
On my spectrum analyzer the 25Hz levels goes all the way up and I hear the noise of it. It's not super clean unfortunately, and if I manage to get rid of that issue, the filter will then be a perfect peace for me to use properly and finally !
I have changed the potentiometer already because the first one was crap. It's meant to be good quality so I assume it's not from this element.
As soon as I tweak the knob by a very little, I have that super strong and inaudible low end value that goes right up.
Any help highly appreciated.
Thanks Smile
g.gabba
PostPosted: Sat May 18, 2019 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
may this threads are related to your problem?
http://electro-music.com/forum/topic-48989-0.html&postdays=0&postorder=asc&highlight=
http://electro-music.com/forum/topic-51644.html
lebarde
PostPosted: Sat May 18, 2019 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers for that one.
I do have the resonance issue too and totally thought it was a bad pot.
I have a better quality one to test and I'll also try what they say there.
But my issue actually comes from the Cutoff knob... no idea if this fix will changed that too. I'll try and post results.
wackelpeter
Audio files: 10
PostPosted: Sat May 18, 2019 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
As far as i remember the noisy resonance pot was just an issue on the CGS Version... not that i haven't noticed it on my Yusynth Version...
I can vaguely remember having done some modifications on ym yusynth build too, but can't remember what they were… checked my printed documents, as sometimes i was clever enough to write down in them what i had done, but there were no notes About it...
But as vague as it is, i'm sure i'Ve done something to tame the resonance a bit…
Maybe i can check my module in the next days and report if i can figure out what i had done or what i haven't done.
