UPDATED - MiniAucle stops working
Page 1 of 1 [2 Posts]
ChamomileShark
PostPosted: Thu Dec 07, 2017 9:32 am    Post subject: UPDATED - MiniAucle stops working Reply with quote  Mark this post and the followings unread
hi, I've asked this in the ChucK forum but so far no joy.
I'd like to be able to use ChucK to create sequencers / sequences which are then played by VSTs within Cubase.
I'd like to check first by sending some simple MIDI from ChucK just to test the set up
I looked at the code in the Kadenze course and also some elsewhere and the simplest example I came up with is;
MidiOut mout;
MidiMsg msg;
if( !mout.open( 0 ) ) me.exit();
144 => msg.data1;
52 => msg.data2;
100 => msg.data3;
mout.send( msg );
1::second => now;
I've set the MIDI out in Chuck as LoopMidi Port and in Cubase I have LoopMidi Port as the MIDI in.
I hit shred it plays. Hurrah! Then I hit play again and it all locks up and I get a "Programme not working" message for the miniAudicle.
Then I realise it's not playing the VST. It seems to be playing a GM piano - even if I don't have Cubase running - or even LoopMIDI - not sure how that's happening.
I haven't had the same issue using PureData or Reaktor (standalone) - they all route the MIDI via loopMIDI ok.
Any ideas?
Music: http://www.soundclick.com/markgriffiths
Info: www.inspiringsounds.com
mario.buoninfante
PostPosted: Sat Feb 24, 2018 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
it seems an issue with the virtual MIDI port. have you tried with different DAWs/softwares?
Mario
