  Various Artists June Solstice live streaming concert
My ChucKs
Page 1 of 1 [6 Posts]
audiodef
Audio files: 42
PostPosted: Wed Mar 14, 2018 1:09 pm    Post subject: My ChucKs Reply with quote  Mark this post and the followings unread
Very recently, and finally, got into learning ChucK. I thought I would share my ChucKs here, just for fun.
Right now I'm messing around with the basics, but it's fun how much noise you can make with just that.
This sounds like a pulsing saw being launched from a cloud of noise.
sawlaunch.ck:
Code:
SawOsc n => TwoPole o => dac;
100.0 => float s;
0.0 => float v;
while(true){
   Std.fabs(Math.tan(v)) * s/200 => o.b0;
   Std.fabs(Math.tan(v)) / s => o.freq;
   Std.fabs(Math.cos(v)) * v => n.sfreq;
   3::ms => now;
   0.9 +=> v;
   o =< dac;
   1::ms => now;
   o => dac;
This variant sounds vaguely like a motor starting roughly, then smoothing out.
motorlaunch.ck:
Code:
20.0 => n.freq;
1::minute/240/8 => dur T; // 240 bpm 32d notes
T - (now % T) => now; // Sync to beat
100.0 => float s;
0.0 => float v;
while(true){
        T/3 => now;
        0.9 +=> v;
        o =< dac;
        1::ms => now;
        o => dac;
Note: I had to disable HTML in this post to get the code to display correctly, due to the < and > in ChucK being mistaken for HTML. EDIT: As originally noted by Kassen. Smile
Audiodef
Gentoo Studio
audiodef
Audio files: 42
PostPosted: Wed Mar 14, 2018 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Depending on how you tweak moe, larry and curly, this could be an arpeggiated Impulse or a modulated buzz - or something funky in between.
moepad.ck:
Code:
// moe
Impulse moe_impulse => BiQuad moe_filter => dac;
.99 => moe_filter.prad; // Goes off the rails and farts itself out at 1.0
1 => moe_filter.eqzs;
5123.0 => float moe_sweep; // Sweeps up to this freq
0.05 => float moe_inc;
// larry
Impulse larry_impulse => BiQuad larry_filter => dac;
.99 => larry_filter.prad;
1 => larry_filter.eqzs;
500.0 => float larry_sweep;
0.06 => float larry_inc;
// Create mathematical relationship between larrylater and larrytimepass
2.3 => float larrylater;
larrylater/1.1 => float larrytimepass;
// curly
Impulse curly_impulse => BiQuad curly_filter => dac;
.99 => curly_filter.prad;
1 => curly_filter.eqzs;
4000.0 => float curly_sweep;
1.03 => float curly_inc;
2.0 => float curlylater;
curlylater/.02 => float curlytimepass;
// all
0.0 => float v;
while(true){
   // Softer at values less than 1.0
   1.0 => moe_impulse.next;
   Std.fabs(Math.sin(v)) * moe_sweep => moe_filter.pfreq;
   // Smaller = more gentle sweep, larger = faster but more quantized sweep
   moe_inc +=> v;
   now + larrylater::ms => time later;
   while(now < later){
      1.0 => larry_impulse.next;
      Std.fabs(Math.sin(v)) * larry_sweep => larry_filter.pfreq;
      larry_inc +=> v;
      larrytimepass::ms => now;
      now + curlylater::ms => time evenlater;
      while(now < evenlater){
         1.0 => curly_impulse.next;
         Std.fabs(Math.sin(v)) * curly_sweep => curly_filter.pfreq;
         curly_inc -=> v;
         curlytimepass::ms => now;
   10::ms => now;
Audiodef
Gentoo Studio
audiodef
Audio files: 42
PostPosted: Wed Mar 14, 2018 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
A simple robot voice:
robot.ck:
Code:
SawOsc saw => BiQuad q => dac;
1::minute/120/4 => dur T; // 120 bpm sixteenth notes
for (5=>int i; true; i++) { // Infinite loop
        Std.rand2f(77, 83) => saw.freq; // Centered around 80 - adjust to taste
        Std.rand2f(0.0, 0.99) => saw.width;
        Std.rand2f(0.0, 0.99) => q.b0 => q.prad => q.zrad => q.a0; // ROBOFILTER
        T => now;
It's easy to adjust this to play a simple random arpeggio with specific notes and an octave multiplier:
arp.ck
Code:
[33,36,40,43,45] @=> int note[]; // MIDI notes, Am 2 oct below middle-C
5 => int oct; // Octave multiplier
        (Std.mtof(note[Std.rand2(0, 4)]))*oct => saw.freq;
        T => now;
Audiodef
Gentoo Studio
audiodef
Audio files: 42
PostPosted: Thu Mar 15, 2018 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a little detuned square osc arp ChucK. As is, it plays a growly, punchy, snappy bass.
squarp.ck:
Code:
SqrOsc sq => LPF lpf => ADSR e => dac;
SqrOsc sq2 => lpf;
1::minute/240/4 => dur T; // 240 bpm sixteenth notes
[9,12,21] @=> int note[];
1 => int oct; // Octave multiplier
7 => int keyshift; // Shift from A-1-C0-A0, in half-notes
1.002 => float detune;
while(true){
   // Set rando everything
        oct*(Std.mtof(note[Math.random2(0,note.cap()-1)])+keyshift) => float freq;
        freq => sq.freq;
        detune * freq => sq2.freq; // 2d osc detuned
        Math.random2f(0.0, 1.0) => sq.gain;
        Math.random2f(0.0, 1.0) => sq2.gain; // Indiv gain for oscs
        e.set(Math.random2(0,50)::ms, Math.random2(0,80)::ms, Math.random2f(0.01, 0.30), T*4);
        Math.random2f(250,2000) => lpf.freq; // Adjust filter range to taste
        Math.random2f(0.1,3.0) => lpf.Q; // Adjust to taste. Higher than 2 is quite snappy
        // Play
        e.keyOn();
        T => now;
        e.keyOff();
        T*2 => now;
Audiodef
Gentoo Studio
audiodef
Audio files: 42
PostPosted: Thu Mar 15, 2018 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was playing with getting two lines to play together. This is a bit of silliness.
choralfun.ck:
Code:
SinOsc s => Chorus c => ADSR e => dac;
SinOsc s2 => Chorus c2 => e;
1::minute/60/4 => dur T; // 60 bpm sixteenth notes
0.2 => c.modDepth => c2.modDepth;
0.2 => c.mix => c2.mix;
T / 2::ms => float tfreq; // Sync mod freq with beat (kind of)
// Larger attack makes more of a hit instead of less. Not sure why.
e.set(5::ms, 10::ms, 0.5, 200::ms);
1.5 => float detune; // Affects chorus beats
1.0 => float cdetune;
function void sinbass(float tempomult, int freqmult, float g){
   while(true){
      Math.random2f(80.0 * freqmult, 160.0 * freqmult) => float oscfreq;
      oscfreq => s.freq;
      detune * oscfreq => s2.freq;
      Math.random2f(tfreq/2, tfreq) => float cfreq;
      cfreq => c.modFreq;
      cdetune * cfreq => c2.modFreq;
      g => s.gain => s2.gain;
      e.keyOn();
      T*tempomult*2 => now;
      e.keyOff();
      T*tempomult => now;
spork ~ sinbass(2.0,1,1);
T*32 => now;
spork ~ sinbass(0.5,3,0.2);
while(true) 1::ms => now;
Audiodef
Gentoo Studio
audiodef
Audio files: 42
PostPosted: Fri Mar 16, 2018 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a simple SinOsc pulsator that depends on modulating "now."
sinpulsator.ck:
Code:
SinOsc op2 => SinOsc op1 => dac;
//880 => op1.freq; // At this level of modulation, op1.freq makes no audible difference.
0.0 => float phase;
3000.0 => float sweepfreq; // 8000 = techno/trance pulse, lower values soften this effect. Muddy at 1000.
400.0 => float gainsweep; // Lower values soften the overall volume and take some of the edge off.
1.1 => float dursweep; // This value produces a nice pulse depending on   above values.
while(true){
   Std.fabs(Math.sin(phase)) * sweepfreq => op2.freq;
        Std.fabs(Math.sin(phase * 1.2)) * gainsweep => op2.gain;
        0.1 +=> phase;
        Std.fabs(Math.sin(phase)) * dursweep::ms => now;
        //2::ms => now; // Duration makes a very large difference here. Comment out above line if using this.
Audiodef
Gentoo Studio
