Feedback instruments / no-input mixer / zero-input mixer
Page 2 of 2 [38 Posts]
Goto page: Previous 1, 2
Acoustic Interloper
Audio files: 83
PostPosted: Sun Apr 24, 2016 6:40 pm    Post subject:
Subject description: March 19, 2016 ZIM video
Here is the video of the ZIM piece from the March 19, 2016 Kutztown Planetarium evening, with yours truly on zero input mixers, Genevieve Smith on the JAWS reader, and Emily Hoch on visual accompaniment generated from the audio via a Processing sketch that I wrote for the June 2015 2-day conference, and which she performed for ZIM there as well. I just watched/listened to this for a second time, and am really pleased with how the set turned out. Thanks to Steve Mokris for recording and posting this set.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Acoustic Interloper
Audio files: 83
PostPosted: Wed May 18, 2016 4:22 pm    Post subject:
Subject description: tuned post-processing on ZIM signals
I have been experimenting with various kind of post-processing FX in Live, downstream from my 3 mixers. All feedback-driven signal generation is in the mixers, with Live FX post-processing downstream from the mixers. The idea is to be able to tickle characteristics of a Live FX without taking hands off the mixer.
Here is a simple example. (I am saving the rest up for the summer solstice webcast.) Tune the stereo pair in my mixer, one to high pitch and the other to low pitch, and then send them to a filtered delay in Live. In the pictured delay I have knocked the mid-range out all together (gain = -infinity), and set the high frequency range to echo at 3 times the period of the low frequency range, giving me multiple rhythms.To get anything out of a delay, things need to change from time to time. Otherwise you just have sustain.
It was necessary to make the feedback higher on the faster delay, otherwise it decays much faster than the other.
You can then sweep pitch from the mixer, manually or using mixer FX, to vary the effect. You could put the Live patch's delays on a foot controller, so as to keep hands on the mixer. I haven't done that yet. This recording just illustrates the basic idea.
The Live patch
 Filesize:  102.06 KB
 Viewed:  256 Time(s)
The waveforms of the recording
 Filesize:  420.21 KB
 Viewed:  252 Time(s)
zim3to1.mp3
The sample recording
 Filename:  zim3to1.mp3
 Filesize:  976.47 KB
 Downloaded:  342 Time(s)
Acoustic Interloper
Audio files: 83
PostPosted: Fri May 27, 2016 4:16 pm    Post subject:
Subject description: Friday Night Cheddar
Practicin' up for Summer Solstice on a 3 ZIM Salad with Live Dressing. I didn't think it went 20 minutes. Cool
FridayNightCheddar.mp3
 Filename:  FridayNightCheddar.mp3
 Filesize:  27.52 MB
 Downloaded:  339 Time(s)
Audio files: 228
G2 patch files: 319
PostPosted: Tue Jun 07, 2016 6:29 am    Post subject:
Barely so - but another nice number Laughing
Nice track!
Acoustic Interloper
Audio files: 83
PostPosted: Tue Jun 07, 2016 8:18 am    Post subject:
Nice track!
Thanks again, Jan! I have a 62-minute whopper cooked up for either June Solstice or a One-Off radio set. The second week in May, after classes let out, is always a burst of pent-up music for me, so I just turned on the recording during three live improv sessions with the mixers, cut out the four best sections with no over-dub or other editing, and voilà: From the No World (The No World Symphony). I am eager to stream it. Very Happy
Thanks for listening.
Acoustic Interloper
Audio files: 83
PostPosted: Sun Jun 26, 2016 9:33 am    Post subject:
Subject description: From the No World
Posted my June 2016 Solstice piece From the No World over here on the Solstice thread. There is a photo of the rig and a discussion of that piece on the first page of the event thread. I always look forward to playing the solstice events during my breaks from teaching. Very Happy
Acoustic Interloper
Audio files: 83
PostPosted: Fri Jun 23, 2017 12:29 pm    Post subject:
Subject description: Channel panning in zero-input mixer
Oh, look, it's been a year! Cool
Attached is a short recording of an exercise. I used the Allen & Heath ZED 12Fx mixer with the Nux Mod Core's PAN effect in the stereo feedback path. Channel 1 on the mixer is set to generate the lower pitch, channel 2 to the higher. I used the ZED's fx unit to add some reverb on the outgoing signal, not in the feedback path, because I like it.
Think about panning for a moment. At the start the PAN is set to slowest rate and 100% dry, so no PAN. The channels are isolated, and just play their mixer-equalizer-determined pitches.
Here is the sequence of PAN parameter changes during this recording:
Start — feedback pan on lowest rate and driest wet : dry ratio.
The two channels run without interacting.
Ramp up wet : dry to 100% wet by 15 seconds.
You get one or the other resonant frequency, not both.
At 1 minute start ramping up pan rate.
At 1:13 the low pitch goes away due to shortened “resonant chamber”.
Rate maximum at 1:30, Slow it back down , at 1:59 back into low mode.
Around 2:10 is automatically shifts between a low-high and
a medium-high pair of pitches.
At 2:52 slow rate, at 3:00 increase it to max at 3:18.
Finally back wet : dry down at dry after 3:20.
In essence, a fast, 100% wet pan interleaves both channels almost simultaneously into one channel, but it switches so fast that the long/low pitches never have time to develop. The part "Around 2:10 is automatically shifts between a low-high and a medium-high pair of pitches." is the most interesting, because it is at a panning boundary where it snaps back & forth between two semi-stable modes of operation without any human interaction. Those state transition regions are always the most interesting in playing ZIM.
Ping-pong delays also interleave the channels to interesting effect. The Mod Core doesn't have that, but the Pan gives a similar, albeit more continuous effect.
Panning170623_00.mp3
PAN mixer exercise per above description, 3:41 duration, Dale E. Parson
 Filename:  Panning170623_00.mp3
 Filesize:  5.07 MB
 Downloaded:  289 Time(s)
L´Andratté
PostPosted: Thu Mar 22, 2018 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, A.I., hell of a thread, thanks for the interesting documents, listened just to TheFinalFive, but from beginning to end and I loved it.
It sounds like synthesis with a very organic/acoustic/"real" touch like a field recording Very Happy
I have always felt drawn toward minimalistic forms- gotta read all this stuff now and suck up some new inspiration.
Thanks
Acoustic Interloper
Audio files: 83
PostPosted: Fri Mar 23, 2018 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
Glad you like it. Very Happy Analog synthesis at its core. From the No World (The No World Symphony) from June 2016 webcast is my favorite no-input mixer + post-mixer-effects so far. I will be playing some ZIM in the mix tomorrow, Saturday 24 March at 17:00 GMT, for the equinox webcast. I haven't had much time to prep, so tomorrow's will be extremely improvised. Cool http://radio.electro-music.com
Acoustic Interloper
Audio files: 83
PostPosted: Sun Nov 18, 2018 7:48 pm    Post subject: Video for first movement of From the No World
Subject description: 19 minute video from my June 2016 solstice performance
Here is a video I created recently to accompany the 19 minute, first movement of my no-input mixer From the No World that I performed in the June 2016 Solstice Webcast. This is my custom visualization software written in the Processing/Java framework while listening to the piece. As with ZIM, there is feedback in this video. First form is manipulation of past frames on the canvas -- feedback over time -- and second form is occasional use of some screen shots of the previous frame as one of the paintbrushes.
Please watch in high-def full screen.
Copyright 2016-2018, Dale E. Parson, Creative Commons Attribution 4.0 International (CC BY 4.0)
Solstice webcast full recording is on this thread.
Audio files: 228
G2 patch files: 319
PostPosted: Sun Nov 25, 2018 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
W Cool W - that's great!
Acoustic Interloper
Audio files: 83
PostPosted: Sun Nov 25, 2018 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan! I still have fun listening to it & watching it. I did the video in one pass on the spur of the moment at bedtime, just me and the dogs.
It didn't get accepted at https://www.imersa.org/summit -- they are oriented towards commercial videos, I think -- but they did accept my 10-minute talk for the work I did in our planetarium during the summer. I've never been to this conference before, in a science center with a big planetarium in Columbus, OH, should be fun.
Sabbatical leave in the spring!!!
Have a Merry Christmas. santa I am pretty sure I will have time after final exams to work something up for New Year's Eve. Cool Take care.
Acoustic Interloper
Audio files: 83
PostPosted: Mon Dec 31, 2018 1:08 pm    Post subject:
Subject description: NYE 2018-2019
My New Year's Eve piece for 2018-2019, Rate of Change, mostly no-input mixer, is posted here.
