Melody Generator XL
Page 2 of 2 [46 Posts]
Goto page: Previous 1, 2
synaesthesia
Audio files: 85
PostPosted: Sat Sep 27, 2014 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Half way through your last posts I started thinking about a smaller version of your circuit that could be used to generate arpeggios.
Now you post the complete circuit - plus all the tables. Very Happy That's great work again. Thanks a lot for posting this!
Audio files: 613
PostPosted: Sat Sep 27, 2014 12:58 pm    Post subject: BIGARP Reply with quote  Mark this post and the followings unread
Here's one I drew up that can step through 8 different chords using the 9 bit divisions.
 Filesize:  86.14 KB
 Viewed:  367 Time(s)
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
Audio files: 613
PostPosted: Wed Oct 01, 2014 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm putting the Chromatic Melody Generator in an enclosure. everything is mounted and some things wired up,
but I can't finished it before I have figured something else out first: Can I rearrange the noteorder to get more musical combinations ?
Of course I can already make all the combinations/chords but I want to group them to correspond with the binary inputs combinations.
note:I'll be ignoring the higher C for now and just work with 1 octave
By changing only 2 inputs at a time you end up with the following 24 permutations:
Code:
DCBA DCBA DCBA DCBA
00xx 01xx 10xx 11xx
0000 0100 1000 1100
0001 0101 1001 1101
0010 0110 1010 1110
0011 0111 1011 1111
DCBA DCBA DCBA DCBA
0x0x 0x1x 1x0x 1x1x
0000 0010 1000 1010
0001 0011 1001 1011
0100 0110 1100 1110
0101 0111 1101 1111
DCBA DCBA DCBA DCBA
x00x x01x x10x x11x
0000 0010 0100 0110
0001 0011 0101 0111
1000 1010 1100 1110
1001 1011 1101 1111
DCBA DCBA DCBA DCBA
x0x0 x0x1 x1x0 x1x1
0000 0001 0100 0101
0010 0011 0110 0111
1000 1001 1100 1101
1010 1011 1110 1111
DCBA DCBA DCBA DCBA
xx00 xx01 xx10 xx11
0000 0001 0010 0011
0100 0101 0110 0111
1000 1001 1010 1011
1100 1101 1110 1111
DCBA DCBA DCBA DCBA
0xx0 0xx1 1xx0 1xx1
0000 0001 1000 1001
0010 0011 1010 1011
0100 0101 1100 1101
0110 0111 1110 1111
Having the notes in the current order (C,C#,D,#,....B) results in the following tables:
Code:
DCBA DCBA DCBA DCBA
00xx 01xx 10xx 11xx
  C    E    G#   _
  C#   F    A    _
  D    F#   A#   _
  D#   G    B    _
DCBA DCBA DCBA DCBA
0x0x 0x1x 1x0x 1x1x
  C    D    G#   A#
  C#   D#   A    B
  E    F#   _    _
  F    G    _    _
DCBA DCBA DCBA DCBA
x00x x01x x10x x11x
  C    D    E    F#
  C#   D#   F    G
  G#   A#   _    _
  A    B    _    _
DCBA DCBA DCBA DCBA
x0x0 x0x1 x1x0 x1x1
  C    C#   E    F
  D    D#   F#   G
  G#   A    _    _
  A#   B    _    _
DCBA DCBA DCBA DCBA
xx00 xx01 xx10 xx11
  C    C#   D    D#
  E    F    F#   G
  G#   A    A#   B
  _    _    _    _
DCBA DCBA DCBA DCBA
0xx0 0xx1 1xx0 1xx1
  C    C#   G#   A
  D    D#   A#   B
  E    F    _    _
  F#   G    _    _
which produces some augmented triads:
xx00: augmented C triad = C E G#
xx01: augmented C# triad = C# F A
xx01: augmented D triad = D F# A#
xx11: augmented D# triad = D# G B
I was trying out some different combinations, reshuffling some notes and typing out all the tables, but after
having done a couple combinations I decided that I might aswell let the computer do it for me Smile
It would probably be possibe to do it in excel but I hardly know anything about it, and I don't even have it installed.
The only thing that I do know a bit about and that's usefull to do it is a combination of html & javascript.
So I started programming, first letting it draw the tables, then automating the chord detection, starting with
just the C chords and after that worked I added the rest. I've uploaded that version here in case anybody wants to play with it
or geek out at the source code Wink
edit: uploaded an updated version that can calculate some permutations
Of course I still have to shuffle the notes around manually to find usefull combinations so I was thinking of automating that process too.
However,. 12 note + 4 empty spaces means there are 16! permutations,. that's: 209.722.789.888.000 Shocked
Of course the 4 empty spaces in there will produces a multitude of equal results so taking those out results in
16!/4! = 871.782.912.000 and there are also a lot of combinations that will produce the same groups of notes.
Actually once I know the first 4 notes it would be most logical to spread the other 8 in an equal manner,
which would reduce the number of possibilities dramatically.
PostPosted: Thu Oct 02, 2014 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm totally lost, but I think all you need to do is find that 216 digit number from which all patterns stem. Smile
James.
Audio files: 613
PostPosted: Thu Oct 02, 2014 11:48 am    Post subject: When I was a little kid my mom told me
Subject description: not to stare into the sun. So, once when I was six I did
I know, I have to get that number! Laughing
this was useful.
I was already testing with the circle of fifths, and drawing other circles with groups of notes.
by skipping a certain number of notes I get these strings:
Code:
 1] C  C# D  D# E  F  F# G  G# A  A# B
 2] C  D  E  F# G# A# C# D# F  G  A  B
 3] C  D# F# A  C# E  G  A# D  F  G# B
 4] C  E  G# C# F  A  D  F# A# D# G  B
 5] C  F  A# D# G# C# F# B  E  A  D  G
 6] C  F# C# G  D  G# D# A  E  A# F  B
 7] C  G  D  A  E  B  F# C# G# D# A# F
 8] C  G# E  C# A  F  D  A# F# D# B  G
 9] C  A  F# D# C# A# G  E  D  B  G# F
10] C  A# G# F# E  D  C# B  A  G  F  D#
11] C  B  A# A  G# G  F# F  E  D# D  C#
So now I'm thinking to divide those strings up either in 3x4 (and add 1x4 empty spaces)
so for the first string that would be:
C C# D D# | E F F# G | G# A A# B | _ _ _ _
or divide in 4x3 and add an empty space for each group so for the first string that would result in:
C C# D _ | D# E F _ | F# G G# _ | A A# B _
Then shuffle the notes of each group around in the same way.
so if you take: C C# D _ | D# E F _ | F# G G# _ | A A# B _
and you switch C# & D then you also need to switch E & F, G & G#, A# & B.
which leaves only 24 permutations for each string. Actually since I want the first note to be a C it's only 6 permutations Very Happy
hmm let's see 11 strings, can be divided in 2 ways, 6 permutations, that's 132 different options,. and a couple of the strings
actually result in the same groups of notes when divided so it's even less then that.
I did already find this nice combination:
Code:
inputstring = C,G,E,B,A,D,C#,F#,G#,D#,_,_,F,A#,_,_,
detected chords:
Major seventh, rootnote: C, notes: C G E B
Major seventh, rootnote: D, notes: A D C# F#
Major seventh, rootnote: G#, notes: C G G# D#
Major seventh, rootnote: A#, notes: A D F A#
Augmented triad, rootnote: C, notes: C E G# _
Augmented triad, rootnote: E, notes: C E G# _
Augmented triad, rootnote: G#, notes: C E G# _
Augmented triad, rootnote: D#, notes: G B D# _
Augmented triad, rootnote: G, notes: G B D# _
Augmented triad, rootnote: B, notes: G B D# _
Augmented triad, rootnote: C#, notes: A C# F _
Augmented triad, rootnote: F, notes: A C# F _
Augmented triad, rootnote: A, notes: A C# F _
Augmented triad, rootnote: D, notes: D F# A# _
Augmented triad, rootnote: F#, notes: D F# A# _
Augmented triad, rootnote: A#, notes: D F# A# _
Major seventh, rootnote: D#, notes: G D D# A#
Major seventh, rootnote: G, notes: G B D F#
Audio files: 613
PostPosted: Thu Oct 02, 2014 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this should work Smile
Code:
C,E,G#,_,A,C#,F,_,G,B,D#,_,D,F#,A#,_,
detected chords:
Major seventh,   rootnote: C,  notes: C E G B
Major seventh,   rootnote: D,  notes: A C# D F#
Major seventh,   rootnote: D#, notes: G D# D A#
Major seventh,   rootnote: G#, notes: C G# G D#
Major seventh,   rootnote: A#, notes: A F D A#
great, a string of notes and some chords but what the hell does it mean ?!
The string of notes is the order in which I will wire the outputs from the diode matrix to the mux. (of the chromatic melody generator)
Which will have the effect that when cycling the bits of 2 of the note CTRL inputs it will produce notes that form a chord.
So it's like the ARP circuits and it can cycle through multiple chords.
Code:
note inputs DCBA = [0000,0001,0010,0011] = C  E  G# _  = Augmented triad: C,E,G#*
note inputs DCBA = [0100,0101,0110,0111] = A  C# F  _  = Augmented triad: C#,A,F*
note inputs DCBA = [1000,1001,1010,1011] = G  B  D# _  = Augmented triad: D#,G,B*
note inputs DCBA = [1100,1101,1110,1111] = D  F# A# _  = Augmented triad: D,F#,A#*
note inputs DCBA = [0000,0001,1000,1001] = C  E  G  B  = Major seventh: C
note inputs DCBA = [0100,0101,1100,1101] = A  C# D  F# = Major seventh: D
note inputs DCBA = [1000,1010,1100,1110] = G  D# D  A# = Major seventh: D#
note inputs DCBA = [1000,1001,1100,1101] = G  B  D  F# = Major seventh: G
note inputs DCBA = [0000,0010,1000,1010] = C  G# G  D# = Major seventh: G#
note inputs DCBA = [0100,0110,1100,1110] = A  F  D  A# = Major seventh: A#
*the only difference between these is the order of the notes.
Also all the notes it produces will be within one octave (unless the octave CTRL inputs are controlled too),
so notes that should be spread apart to form a chord will now be closer together.
Audio files: 613
PostPosted: Sat Oct 04, 2014 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finished wiring it up and it works great Very Happy
I connected some resistors to the octave divider for a stepped saw output,
(fixed octave) and added a CV input aswell.
Maybe I'll add an attenuator to that later using the spare opamp.
Here are some photos and an updated schematic.
edit: I noticed some mistakes in the schematic, so uploaded a fixed version.
 Filesize:  80.27 KB
 Viewed:  246 Time(s)
 Filesize:  61.37 KB
 Viewed:  222 Time(s)
 Filesize:  108.11 KB
 Viewed:  225 Time(s)
 Filesize:  137.17 KB
 Viewed:  410 Time(s)
droffset
PostPosted: Wed Oct 15, 2014 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
This is so cool Phobos, thanks for sharing. Now I want one. Smile
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
Audio files: 613
PostPosted: Wed Oct 15, 2014 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Dr.Offset, I'm having a lot of fun with it Very Happy.
It played a prominent part in Sprut Flup and was used for Chromatoes aswell.
I have some more recordings but need to sort those out first.
Audio files: 613
PostPosted: Sun Oct 19, 2014 7:18 am    Post subject: The Close Encounter Reply with quote  Mark this post and the followings unread
I haven't tested this but it should play the 5-note sequence from Close Encounters of the Third Kind.
Add a LM386 and a speaker and you could use it as a doorbell. Wink
"The Close Encounter" schematic (untested)
 Filesize:  57.43 KB
 Viewed:  301 Time(s)
trav
PostPosted: Wed Oct 22, 2014 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
How did I miss this thread?! (with references to my muddling experiments and everything)
This is very nice. Something like it will have to find its way into my new project (will start a new thread soon). Already have a bunch of spare 16bit stuff due to an overthought sequencer idea.
trav
PostPosted: Sat Oct 25, 2014 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
PHOBoS, did you look at the possibility of using a 4059 divide-by-n counter to do the same? Use a mux to programme the jam inputs, or even use 12 (or 13) 4059s for polyphony. I am still getting my head around the datasheet for this chip, but should work.
Audio files: 613
PostPosted: Sat Oct 25, 2014 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thought about it but haven't really looked into it. Though it looks like it's not just a matter of making some pins high/low
to set the division, but there is some feedback involved aswell. So switching between the notes might not be very easy
and require a networks of logic gates. It should work pretty well for polyphonic use, although I'm not sure if it
would be much easier then using a bunch of 4040's. hmm it would be nice if there's a chip with several /2 counters. scratch
synaesthesia
Audio files: 85
PostPosted: Sat Oct 25, 2014 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Looked for this as well. The quad FF chips I know all have a common clock. But you could use a dual FF chip like the 4013 and connect NOTQ to D, which gives you two toggle-FF per chip.
Audio files: 613
PostPosted: Sat Oct 25, 2014 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
yep. common CLK seems to be the problem,. I was looking at the 74LS377 which has 8 flip flops but also has a common CLK.
(and besides that no inverted output which it would need to work as a divider)
PostPosted: Sun Oct 26, 2014 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
What about using a 4007 to build several latching transistor pairs? They have 3 N/P pairs, so you should be able to make 3 divide by 2 circuits on one chip.
Audio files: 613
PostPosted: Sat Nov 22, 2014 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Back to what I started with, a 4 bit Melody Generator. I had ordered some CMOS comparator chips (CD4063), but not tested yet.
Just did that so here's a working version using 2 chips. Cool
Melody Generator XL - V4.0
 Filesize:  43.45 KB
 Viewed:  362 Time(s)
mike page
PostPosted: Mon Apr 02, 2018 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Was this ever tested?
Also are the pulses that clock the 2nd half of the 4520 really tiny?
Audio files: 613
PostPosted: Mon Apr 02, 2018 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes it was tested (read the comment again).
And indeed, the pulses are really narrow, so that might not work if you want to use it in a multiplier setup Wink.
The output of the 2nd 4520 has a nice 50/50 dutycyle though, of course at half the frequency.
mike page
PostPosted: Mon Apr 02, 2018 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah thanks, maybe i'll try a crude little transistor pulse extender type thing, but im not too hopeful about that in this application... hmmm more thinking...
mike page
PostPosted: Tue Apr 03, 2018 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
...Or maybe to make the output pulse bigger some sort of latching thing in conjunction with the original input osc? Like it latches on when the output and the osc are high, then stays high till they are both off?
Dont know how to do this though! And would probably be too many components to make it worthwhile...
