Tube VCF on Dutch synth forum
Page 3 of 3 [70 Posts]
Goto page: Previous 1, 2, 3
j.baars
PostPosted: Sat Sep 20, 2008 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
the resistor at 15 volts should be 350 0hms, use a 1 watt type .
the diode thingie is to keep the filament (heather) voltage aproxx. 0,7 volts.
I did use the antiparallel confg to make sure the filament is not burned when the powersupply is
accidently inverted when experimenting.
bye,
jeroen baars
Luka
PostPosted: Thu Oct 30, 2008 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
mr baars
was the mosfet chosen for it's particular attributed or can i substitute with another fet like mpf102. just wondering if you used that as you had it on stock or if it is crucial for the design
well im going to try this today, hopefully it works, ill post my results
problemchild
melbourne australia
j.baars
PostPosted: Fri Oct 31, 2008 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
the fet is used as a variable resistor, you can use almost every substitute you can find.
even a npn transistor will do the job. ( with more distortion )
you can find another tube filter design here; http://www.synthforum.nl/forums/showthread.php?t=96176&page=4&highlight=diy+modulair
bye,
jeroen
Luka
PostPosted: Fri Oct 31, 2008 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks jeroen
problemchild
melbourne australia
crashlander42
PostPosted: Sun Nov 23, 2008 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I breadboarded the tube VCA and am pleased with it's sound. It almost sounds filterish. It has a neat woosh. I added a mod to it that acts almost like an amount pot, but also changes the timber. It's actually Frequency Central's "HiGain" mod for his pentadriver with a 100k pot instead of a 68k resistor.
Really, this seems to act more like a PWM than a VCA, but it does the trick. Even with the original design.
Anyway. Here's a video. http://www.youtube.com/watch?v=3SxKiEdGgxo
When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr
Luka
PostPosted: Mon Nov 24, 2008 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
did you put resistors on your freq pot to restrict the voltage?
problemchild
melbourne australia
frequencycentral
PostPosted: Mon Nov 24, 2008 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
That sounds most excellent! Seeing as how you mentioned it, here's the Pentadriver MkII with the high gain mod. It's posted elsewhere on the net ( I mostly hang out at the DIY Stompbox forum http://www.diystompboxes.com/smfforum/forums.html?topic=71381.0), but now it's here too.....
http://www.frequencycentral.co.uk/
LektroiD
PostPosted: Wed Jan 07, 2009 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm quite interested in this, I wonder how easy or hard it will be to transfer to stripboard? Since I don't have an etching kit.
janvanvolt
PostPosted: Mon Feb 23, 2009 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
HELP!
I am still having issues with my two built tubes.
They still do not work (as expected).
I am using this here: http://www.casia.org/modular/SF/tubevcf.jpg
(which the grounding of course) BUT:
a) if i turn input counterclockwise, i still have an input signal.
b) Resonance also does not work as expected.
I simply didn't get the "tube" sound at all, more or less a "passing" signal.
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
janvanvolt
PostPosted: Sun Mar 01, 2009 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
*sigh*
nobody able to help me ?
Luka
PostPosted: Sun Mar 01, 2009 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
i got a couple dud 5672s in my batch
had you tried replacing them?
also are you sure your tube is orientated correctly?
it is really confusing with j.baars schems as he numbers them with a different orientation to the datasheets. you have to pay attention to the dot not the numbers. i think he said in this thread that he copied the numbering format from an old schematic but it is something to be aware of.
i havent made the filter but i have made the vca. i have a modded version with an input mixer, negative bias on the grid and output amping. the output amp can move the distortion more towards opamp distortion and not purely tube but i like the outcome. once i have properly tested it i will post the design.
problemchild
melbourne australia
janvanvolt
PostPosted: Wed Mar 04, 2009 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Luka,
a) the red dot is (hopefully) correct, it will be on the "upper" direction.
b) i have built two pcb's from this forum post, both are acting same strangely.
c) i can try to get other 5672 tubes...
crashlander42
PostPosted: Wed Mar 04, 2009 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I build the VCF from the schematic and was never happy with how it sounded. It doesn't really seem to filter, just passes sound thru. There is resonance though. It's weird. I should probably breadboard it and play with it.
My DIY stuff Flickr
Luka
PostPosted: Thu Mar 05, 2009 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
ill give the vcf circuit a go on my breadboard next week jan
ill let you know how i go.
i know that my vca didnt work first time when i used the initial layout but i think that was due to a bad etch and perhaps a bad tube. once i studied the circuit i decided i wanted to change it anyway.
One thing i was told by eric from metasonix in respect to the tube designs is that they need a negative bias on the grid. This circuit doesnt include that. He suggested -0.4v for the 5672. I have implement this into my vca design. I might try it when i breadboard the vcf and see if it makes a difference.
problemchild
melbourne australia
janvanvolt
PostPosted: Fri Mar 20, 2009 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Too bad that my VCF still doesn't work Sad do you have an update on the breadboard design ?
Ayab
PostPosted: Sun May 28, 2017 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
quick questions
some of my friends are running on 12v supplies. will this be possilble for this module?
I realised that the schematic is for 12V Embarassed
Going to give it an etch Laughing
Ayab
PostPosted: Fri May 04, 2018 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I want to etch a mean sucker vcf but I don't understand part of the schematic I have outlined in pink on the schematic (pictured under the layout below):
Specifically:
1. What does "Rx" mean? (alternately a fixed resistor?)
2. What is the dotted line between 'Rx or 1m Lin' that leads to 'input'. How do I connect this in a circuit?
3. What do the two slashes on either side of 'Rx 220k' after 'input' mean?
The pcb by Etaion (see green layout below for ease of reference) seems to match the schematic other than the 350r resistor which is for +15V and I will run it on +12V with a 275r resistor. If anyone can see any other differences please let me know.
Thanks very much.
 Filesize:  75.49 KB
 Viewed:  108 Time(s)
 Filesize:  14.72 KB
 Viewed:  118 Time(s)
Ayab
PostPosted: Thu May 10, 2018 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I realise that this probably means either 1m lin potentiometer or R 220K but can someone please confirm.
Audio files: 228
G2 patch files: 319
PostPosted: Thu May 10, 2018 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
That is my interpretation too, select one of both options.
Ayab
PostPosted: Thu May 10, 2018 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan
As you think so I will use 1m linear pot instead of 220k
Appreciate your help and will let you know how it works out
