  Twyndyllyngs Live Chez Mosc
Yusynth on Stripboard
Page 1 of 1 [11 Posts]
helix_modular
PostPosted: Thu May 03, 2018 1:00 pm    Post subject: Yusynth on Stripboard
Subject description: A growing collection of stripboard implementations with suggested mods.
Dear EMs,
with permission of Yves Usson I intend to share my stripboard layouts of various Yusynth modules. I am very thankful for Mr. Usson's amazing work and I learned a lot in the process of designing the stripboards. Each layout has links to his homepage, after all there is the reference for wiring and the like.
All posted layouts are tested and verified.
A word on my design guidelines:
I tried to maintain a board format that fits behind a 5u standard panel in 'sandwich' configuration, much as the original designs.
The power section is intentionally very generous to be readily adapted to your needs. For my part I use 2x5 Eurorack connectors but feel free to modify. Just make sure these 10Ohm resistors are in series and the caps in parallel and grounded (!).
The provided PDFs are true to size. Print with a ratio of 1:1 and it fits your standard stripboard perfectly!
Feedback is highly welcome and appreciated. Time to give this amazing community something back!
    CV Generators
      Auto-bend
      Dual Gated Slew
    Signal processors and modifiers
      MinMax
    Control/GATE generators and modifiers
      Dual Gate Delay
      Dual Pulse Delay
      Clock Divider
      Comparators
All the best & happy soldering,
helix modular
helix_modular
PostPosted: Thu May 03, 2018 1:02 pm    Post subject: Yusynth Autobend
Subject description: Stripboard
Yusynth Autobend
http://yusynth.net/Modular/EN/AUTOBEND/index.html
Yusynth_Autobend.pdf
 Filename:  Yusynth_Autobend.pdf
 Filesize:  110.63 KB
 Downloaded:  145 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:04 pm    Post subject: Yusynth Pulse Delay
Yusynth Dual Pulse Delay
http://yusynth.net/Modular/EN/PULSEDELAY/index.html
Yusynth_DualPulseDelay.pdf
 Filename:  Yusynth_DualPulseDelay.pdf
 Filesize:  105.77 KB
 Downloaded:  136 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:05 pm    Post subject: Yusynth Dual Gate Delay
http://yusynth.net/Modular/EN/GATEDELAY/index.html
Yusynth_DualGateDelay.pdf
 Filename:  Yusynth_DualGateDelay.pdf
 Filesize:  109.63 KB
 Downloaded:  127 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:06 pm    Post subject: Yusynth Dual Gated Slew
http://yusynth.net/Modular/EN/DUALSLEW/index.html
Yusynth_DualGatedSlew.pdf
 Filename:  Yusynth_DualGatedSlew.pdf
 Filesize:  126.86 KB
 Downloaded:  124 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:13 pm    Post subject: Yusynth Min Max + Inverter Mod
Yusynth Min Max + Inverter (Mod)
http://yusynth.net/Modular/EN/MINMAX/index.html
I've added two simple inverting opamp circuits to 'complete' this module in a sense of analog boolean logic: MIN = AND, MAX = OR, INV = NOT.
Inverter may be easily omitted.
Yusynth_MinMax_Inv.pdf
 Filename:  Yusynth_MinMax_Inv.pdf
 Filesize:  133.68 KB
 Downloaded:  129 Time(s)
Audio files: 609
PostPosted: Thu May 03, 2018 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Since you're good at making stripboard layouts you might be able to help out here. Very Happy
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
billsaban
PostPosted: Sun May 06, 2018 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanx a lot for this
helix_modular
PostPosted: Mon May 07, 2018 12:21 pm    Post subject: Yusynth Clock Divider
http://yusynth.net/Modular/EN/DIVIDER/index.html
Modification (suggestion) with reset on rising clock (instead of falling, as in original design) included. Please also refer to this thread:
http://electro-music.com/forum/topic-69933.html
Mounting:
As there's a lot of wiring to be done, I suggest to mount the board in L-configuration. This keeps the wires to the rotary switches short and tidy.
Update (2018-06-05): small image of the reset mod included.
Yusynth_Clockdivider-ResetMod-img.pdf
 Filename:  Yusynth_Clockdivider-ResetMod-img.pdf
 Filesize:  208.12 KB
 Downloaded:  120 Time(s)
Last edited by helix_modular on Tue Jun 05, 2018 12:13 pm; edited 2 times in total
helix_modular
PostPosted: Mon May 14, 2018 1:06 pm    Post subject: Yusynth Comparators
Yusynth Comparators
http://yusynth.net/Modular/EN/COMPARATORS/index.html
Suggestions for different thresholds included. I think this circuit may be simplified in a few places, too (which makes it possible to avoid hookup wires on the board).
Yusynth_Comparators.pdf
 Filename:  Yusynth_Comparators.pdf
 Filesize:  123.04 KB
 Downloaded:  118 Time(s)
MapacheRaper
PostPosted: Mon Jun 18, 2018 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im loving this thread
