  Various Artists electro-music.com March Equinox Concert
M185 sequencer Project - Software Update !!
Page 38 of 39 [974 Posts]
Goto page: Previous 1, 2, 3, ..., 36, 37, 38, 39 Next
ryktnk
PostPosted: Sun Apr 15, 2018 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Alfredo wrote:
Yes ryktnk, we are ready for your kits!
Thanks.
I have found a source for 8-way switches, so I will be
offering those with the kits, possibly with a panel PCB
to make assembly mutch easier.
I am in the middle of redesigning the PCBs, for easier
assembly [ lots less transistors, resistors ].
Also there will be more options for each stage setting than
before, so rythmially the new version will be a lot more fun.
Sorry it's taking a while, it is not my day job.
More soon . . .
-ryk
Appliancide*
PostPosted: Sun Apr 15, 2018 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will take two sets of whatever you end up offering.
http://appliancide/blogspot.com
Xahdroid
PostPosted: Sun Apr 15, 2018 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great! Thanks for the update!
beautyofdecay_
PostPosted: Mon Apr 16, 2018 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Looking forward to the new version! Cool
www.ecalpemos.nl
NS4W
PostPosted: Mon Apr 16, 2018 11:00 am    Post subject:   Reply with quote  Mark this post and the followings unread
Will the switches be rotary in the updated version?
Thats great - more playable IMO
ryktnk
PostPosted: Fri Apr 20, 2018 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can make the it with which ever switch you like !
There is a link a page or do back in the thread for some
nice mini rotaries, or I will hopefully be offering 8-way
slide switches.
Marizu
PostPosted: Wed May 09, 2018 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like a PCB & switches, please . I'll send you a PM.
Mine will most likely be going into eurorack format.
Paradigm X
PostPosted: Wed May 09, 2018 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Will you be offering switches separately? ive got a pcb and PIC from last time, but no switches, so has sat around in the todo pile
thanks
ryktnk
PostPosted: Thu May 10, 2018 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Good news !
I found a source of new 8way slide switches, they are a bit smaller
than the previous ones.
The big difference is these are PCB mount, the old ones had threaded
holes and could be panel mounted.
Any one have a preference ?
-ryk
 Filesize:  1.16 MB
 Viewed:  167 Time(s)
Ayab
PostPosted: Thu May 10, 2018 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Well done! I am sure those will be better for a control pcb, if you are still planning one. Also always good to save a little space.
Hope the design is going well.
PWM
PostPosted: Thu May 10, 2018 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can get these here in the Netherlands. I reckon they should be obtainable from another source as well.
https://www.eoo-bv.nl/schuifschakelaar/9436-schuif-8.html
Alfredo
PostPosted: Fri May 11, 2018 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Good news !
-ryk
I don´t think in this case smaller switches are better for a control of eight positions switch.
ryktnk
PostPosted: Fri May 11, 2018 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link.
I have never seen this size with PCB legs before.
Alhtough it is a shame they dont have normal knobs.
-ryk
Ayab
PostPosted: Fri May 11, 2018 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Alfredo - you make a very good point and usability should be the utmost consideration.
Ryk says they are 'a bit' smaller so hopefully not enough to affect the programming?
ryktnk
PostPosted: Mon May 14, 2018 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Alfredo wrote:
ryktnk wrote:
Good news !
-ryk
Travel is 2.5mm per pole, as apose to 3mm per pole on the larger switches,
so I think they are still quite usuable.
They are the same swithces used on the famous "inspired" by ryk m185
Eurorack modules.
Unfortunately these are all I can get hold of, unless people prefer
the larger panel mount switches with solder tags.
-ryk
Ayab
PostPosted: Mon May 14, 2018 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
As you think they are perfectly usable I am sure I would be very happy.
Xahdroid
PostPosted: Mon May 14, 2018 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good to me! I think I would favour these over the larger panel mount for sure.
Alfredo
PostPosted: Tue Jul 10, 2018 2:02 am    Post subject: Switches Reply with quote  Mark this post and the followings unread
Yes Mister ryktnk! Those switches are fantastics!
So the project can be revived soon?
Thanks and best wishes!
ryktnk
PostPosted: Tue Jul 10, 2018 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
It's not a done deal, the smaller switches have an akward
schematic.
Kind of 8P 1T rather than 1P 8T !
So I might prefer using the original slightly bigger ones, which do
allow for panel mount if needed.
-ryk
Alfredo
PostPosted: Tue Jul 10, 2018 10:00 am    Post subject: Bigger is better Reply with quote  Mark this post and the followings unread
Yes, bigger is better!
Sammus
PostPosted: Wed Jul 18, 2018 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Keen for 2!
DANalog808
PostPosted: Wed Aug 15, 2018 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hi
schematic.
-ryk
I think you should use the original, bigger ones please... Thanks!
Ayab
PostPosted: Wed Aug 15, 2018 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I can also recommend the 16mm mini rotary switches which I think ryktnk suggested earlier in this thread. I ordered some from eBay for another project and fyi the company "leg-switch" are honest and very helpful. Although they sent me 2p4T by mistake, when I realised and told them they immediately sent me the correct 1p8T (even though I didn't realise for 2 months!) they work fine and are pretty good quality.
sorry about long link! :-
https://www.ebay.co.uk/itm/2pc-4-8-Way-Selector-16mm-Rotary-Switch-15mm-Knurled-Shaft-Used-PCB/112073905103?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Daa5d2b8aee9e47a8ae8b79ffb40aa6a9%26pid%3D100675%26rk%3D3%26rkt%3D15%26sd%3D192465679901%26itm%3D112073905103&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Aea01488c-a0b4-11e8-ad0f-74dbd180c2da%7Cparentrq%3A3ebdcf711650aa4799fd4959fffb0b22%7Ciid%3A1
 Filesize:  382.72 KB
 Viewed:  125 Time(s)
RobJB06
PostPosted: Sun Aug 26, 2018 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello ryktnk,
I would like to express interest in buying 2 complete kits with sliders/pots any other associated parts please when these become available again
Thanks
GetzM
PostPosted: Tue Sep 25, 2018 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
pm sent!
Been drooling over this for a long time now Smile
