sMs SN Voice Build
Page 1 of 1 [2 Posts]
matinnin
PostPosted: Tue May 15, 2018 7:20 am    Post subject: sMs SN Voice Build
Subject description: built and done - ? Mixer select A - C
edit: i've looked a little deeper and see it will do it, i just need to figure out how to switch it between on/off on pin 25/26/27
i've finished my first sMs board SN voice Build, MOTM style. the default setup for the output is Either Noise or Pulse. I was somewhat expecting this Voice would mix the pulse and the noise? the documentation shows a 10k output pot , which is not on the MOTM panel, i paneled mine to emulate the MOTM panel available.
i'm wondering what the referenced Mixer select A , and Mixer select C are for? my switch(S2) is J2-6 , which outputs to J3-1 ,
does either of these mixer sel options mix noise and pulse? or what do they do?
thanks,
https://www.youtube.com/watch?v=yIrfZYETt5Y
PostPosted: Fri Dec 28, 2018 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This should clarify things.
Bill
 Filesize:  196.01 KB
 Viewed:  4 Time(s)
