ChucK 1.4.0.0 mixes up --in and --out args
Acoustic Interloper
Audio files: 84
PostPosted: Sun Jul 29, 2018 7:00 pm    Post subject: ChucK 1.4.0.0 mixes up --in and --out args Reply with quote  Mark this post and the followings unread
I posted this in the ChucK mailing list, thought I should put it here in case anyone tries to use ChucK 1.4.0.0 to steer spatial sound:
Just upgraded my osx upgraded to 10.12.6 from 10.9.x, just installed chuck-1.4.0.0, am writing a new chuck patch. Lots of variables. Two days of debugging later:
chuck-1.4.0.0 is not finding dac.chan(N)s correctly with chuck-1.4.0.0, so I pulled a chuck-1.3.2.0 off of an old mac, and my patch works fine.
This is in a Live -> Soundflower -> ChucK -> MOTU driver signal path, which I took apart a piece at a time. When it looked like ChucK, I turned on verbose mode. When I run this command line with MOTU as my output:
/usr/local/bin/chuck.1.4.0.0 --verbose:10 --out:8 # Note: internal mic is the input, MOTU is output, str8.ck is this:
adc.left => dac.chan(2) ;
adc.right => dac.chan(3) ;
90000::ms => now ;
Nothing goes to the MOTU, and the diagnostics show this:
[chuck]2:SYSTEM): initializing audio I/O...
[chuck]2:SYSTEM): | probing 'real-time' audio subsystem...
[chuck]7:FINE!!): | initializing RtAudio...
[chuck]7:FINE!!): | | trying 8 input 2 output...
[chuck]3:SEVERE): | allocating buffers for 256 x 8 samples...
[chuck]2:SYSTEM): | real-time audio: YES
[chuck]2:SYSTEM): | mode: CALLBACK
[chuck]2:SYSTEM): | sample rate: 44100
[chuck]2:SYSTEM): | buffer size: 256
[chuck]2:SYSTEM): | num buffers: 8
[chuck]2:SYSTEM): | adc: 0 dac: 0
[chuck]2:SYSTEM): | adaptive block processing: 0
[chuck]2:SYSTEM): | channels in: 2 out: 8
Notice the "trying 8 input 2 output..." is wrong. There are symptoms that agree with this. If I increase --in above 2 and just do straight stereo in => out, it starts outputting to chan(0), chan(1), up through chan(N), and N is the --in command line argument.
This older version works fine, sends the mic input pair to the correct dac.chans:
$ ./chuck --version
chuck version: 1.3.2.0 (chimera)
mac os x : intel : 64-bit
http://chuck.cs.princeton.edu/
http://chuck.stanford.edu/
./chuck --verbose:10 --out:8 str8.ck
[chuck]2:SYSTEM): initializing virtual machine...
[chuck]7:FINE!!): | | trying 2 input 8 output...
[chuck]2:SYSTEM): | locking down special objects...
[chuck]2:SYSTEM): | allocating shreduler...
[chuck]10:ALL!!): | adding 'Chuck_Object' (0x100712ff0)...
[chuck]10:ALL!!): | adding 'Chuck_Object' (0x1007130b8)...
[chuck]2:SYSTEM): | allocating messaging buffers...
[chuck]2:SYSTEM): | behavior: HALT
[chuck]2:SYSTEM): | adc: 0 dac: 6
"trying 2 input 8 output..." is correct for 1.3.2.0, but not for 1.4.0.0. Chans are buggy, at least on my mac.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
