Store default values with MIDI
Page 1 of 1 [16 Posts]
vou
PostPosted: Thu Aug 02, 2018 3:47 am    Post subject: Store default values with MIDI
Subject description: Using Sysex function to store an absolute default patch
Hey all,
I've been experimenting with g2 lately with using SuperCollider/Tidal and I'd like to store the initial values of a performance before I send any CC and change the overall parameters
the idea is to recall a patch with the "default" parameters at any given time.
I am thinking in order to this, I can use the 'dump one' function to get midi data in Sysex format and then parse it in SuperCollider later to be sent as MIDI CC back to G2.
I was curious if this would be the right way of doing this or maybe some other folks have done this before
Open to any suggestions
Audio files: 228
G2 patch files: 319
PostPosted: Thu Aug 02, 2018 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not use "All Controllers Request"? (manual page 149/150)
vou
PostPosted: Thu Aug 02, 2018 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, thanks for the reply! Doesn't it only give me the CC'd parameters rather than all of the parameters in the patch?
vou
PostPosted: Thu Aug 02, 2018 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
On a side but related topic, I think one of the issues I am having right now is not being able to preserve a patch properly. My patches seem to be evolving a bit after each session hence this effort to keep a default state.
Audio files: 228
G2 patch files: 319
PostPosted: Thu Aug 02, 2018 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes .. CC-ed ones only ... so indeed you'll have to ask for the patch and then parse that ... or just send the whole dump back maybe ... yuck Confused
O .. and welcome
vou
PostPosted: Thu Aug 02, 2018 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
O .. and welcome
Delighted to be here Smile
So yea that's what I was thinking. However, I am unsure about the G2's Sysex protocol. also can't say that I have much experience using Sysex but in SC the format goes like this:
Code:
 m.sysex(Int8Array[0xf0, 0x00, 0x20, 0x3c, 0x02, 0x00, 0x61, 21, 54, 0xf7]);
Above is an example of the clock message for Machinedrum.
I am sure people has experimented with it before but my initial search didn't really give any results. Maybe you can point me to the right direction?
thanks again Smile
Audio files: 228
G2 patch files: 319
PostPosted: Fri Aug 03, 2018 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
This is what I have ... http://www.bluehell.nl/iaf/html/nm-open/nm-open-g2info.htm
Electromagnetic Wave
G2 patch files: 37
PostPosted: Thu Aug 23, 2018 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi vou!
Did you tried : Shitf + #variation ?
You can use dump too. But after when you send back the sysex G2 performance at 110 BPM (recorded at 30 BPM) somewhere at the middle of your project > your sequencer and the G2 will probably don't like that.
I store all G2 performances on my sequencer with sysex dump when I work on a project. Like this I'm sure the patches/performances are exactly the sames when I recall them with the project. Another reason why I save all G2 performances with project is when I have many versions (v11, v12, v13, v21, etc..). I don't want to take a lot of G2 memory for each performance version for this project.
I only save performance in G2 for live act and all my basic collection of patches/performances
But if you just need to recall the default parameters > shitf + #variation.
vou
PostPosted: Thu Aug 23, 2018 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
How do you actually do that/which sequencer? do you have some sort of a parser?
G2 patch files: 37
PostPosted: Thu Aug 23, 2018 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I make cofee and will record a small video for you. What is a parser ?
Edit : Here is the video, G2 receive perf from sysex (at 1.50 I reset the variation) :
https://youtu.be/qEDdUaAdP9o
And a second video because I forgot to made another one with G2 sending perf with sysex message to sequencer and record it :
https://youtu.be/jjTyRLWJbU8
Let me know if you have question
Smile
vou
PostPosted: Fri Aug 24, 2018 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for that,
Ah so the Sysex gets parsed automagically. I guess they've made it so that it works within the established Sysex protocol. Not sure why I thought it wouldn't.
Just for the sake of this conversation, I use custom interface to sequence nord, not a conventional hardware sequencer
vou
PostPosted: Fri Aug 24, 2018 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
With the motivation I got from you, I was able to come up with SuperCollider patch to save/load performances from sysex just like you demonstrated with your sequencer.
In case that anyone else search for this, here's a working solution;
Code:
//Init MIDI
MIDIClient.init;
MIDIIn.connectAll;
//Get MIDI device
~nord = MIDIOut.newByName("USB MIDI Device", "Port 1");
//Create Arrays to store G2 performances/patches
~vsv1 = Array(50);
//Init Sysex listener
MIDIIn.sysex = {
   arg src, sysex;
   ~vsv1.add(sysex);
   sysex.postln;
//Load the patch back to G2
for (0, 50, { arg i;~nord.sysex(~vsv1[i])});
Cheers!
G2 patch files: 37
PostPosted: Sat Aug 25, 2018 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Niiiiiiiiice!!! Very Happy
Some tools (open source) around here can convert .pch2 to sysex (no need to turn on the G2). I mention that in case you need to convert a lot of patches/perf (.pch2,. prf2 batch folder).
vou
PostPosted: Sat Sep 01, 2018 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh ye? that's interesting.. mind pointing out some of these tools?
G2 patch files: 37
PostPosted: Sun Sep 02, 2018 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
After spending some time searching on my HD, I'm not sure which tool and source I used. But here's what I can tell you about it:
The NMG2 Editor 0.26 can load/save patch from/to G2 with sysex. Exemple : Menu > Sysex > Get patch sysex from bank. The code source and all reference is available with the editor. This editor is available on the forum I think. Or google it.
I see another tool in my computer : pch2midi - NM G2 patch/performance <> MIDI converter. I think this tool was made by Blue Hell (not sure). This tool is coded with delphi. pch2/.prf file can be converted to .bin.
I don't think I used G2ools (which you can find on the forum) code with python language for this task. I remember having already done this task. But it must be around 10 years and I'm not sure what I used. I have some pieces of code here and there that I must review to understand its function.
I don't know if it can be useful for you with SuperCollider/Tidal and I do not have much experience on this subject > You can use the NMG2 0.26 and the FMX FM v0.4 (another open source editor) over TCP IP. These 2 editors have log file, it can be useful too. Then you can send USB message manually for the G2.
I'll let you know if I find / remember the piece of code or the tool I used to convert patches/perf to sysex. I think that some members here would have the time to code this kind of tool the time that I look in my computer and that I write this message. Rolling Eyes
G2 patch files: 37
PostPosted: Mon Sep 17, 2018 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just came across this topic. The tool I used look to be pch2midi from Blue Hell. gomidas said he will use it too as a command line for big folders.
http://electro-music.com/forum/post-277137.html#277137
