Expert Sleepers DIY way
Page 1 of 1 [9 Posts]
MapacheRaper
PostPosted: Sun Aug 12, 2018 1:28 am    Post subject: Expert Sleepers DIY way Reply with quote  Mark this post and the followings unread
I have one 4 IN 4 OUT soundcard that I would like to turn it into an experts sleepers sort of module to interface the computer with the modular
Im guessing that I would need 2 TL074s to buffer the ins and outs. 100k impedances in the ins, 1K in the outs and trimming the opamps for +-10v ranges in the outs and +-1V in the ins. I´d be using only the +ins of the opams, the inverters should go to ground.
Is that correct?
Could I use just voltage dividers for the ins and just buffer the outs?. If you have tips or suggestions about building something like this it would be very appreciated. Im quite a newbie and I dont want to magicsmoke the soundcard.
The soundcard is a MAYA 44, but I guess all then works in more or less the same fashion/voltages, probably around 1 to 3v maximum (targeting 1v for security)
Audio files: 33
PostPosted: Sun Aug 12, 2018 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a good chance that the soundcard may be AC coupled, and get grumpy about DC control voltages.
g.gabba
PostPosted: Sun Aug 12, 2018 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
outputwise there is a guy on MW who did it with a cheap usb soundcard
https://www.muffwiggler.com/forum/topic-162610.html
MapacheRaper
PostPosted: Sun Aug 12, 2018 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I didn´t thought in th DC coupling at all.
The diamond soundcard experiemtn is exactly the same idea. You have saved me a ton of time again.
Thanks!! Wink
MapacheRaper
PostPosted: Sun Sep 02, 2018 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
So I have built this. The idea is to buffer the audio inputs and amplify it to eurorack levels.
When I breadboarded it I would swear it was working, but now Im getting half of the amplitude of the signal instead of multiplying x4 as it should.
What Im messing??
 Filesize:  49.45 KB
 Viewed:  45 Time(s)
 Filesize:  122.52 KB
 Viewed:  40 Time(s)
MapacheRaper
PostPosted: Sun Sep 02, 2018 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The frontal. Lasercutted on wood
 Filesize:  98.79 KB
 Viewed:  35 Time(s)
g.gabba
PostPosted: Sun Sep 02, 2018 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
try this
with the resistor combination of 100k/390k the opamp will amplify the signal by 4,9.
if you need the factor 4 you should use 100k/300k or 33k/100k.
GL
 Filesize:  589.14 KB
 Viewed:  38 Time(s)
 Filesize:  607.32 KB
 Viewed:  45 Time(s)
MapacheRaper
PostPosted: Sun Sep 02, 2018 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
g.gabba wrote:
try this
GL
Yeah, that´s it. If someday you come to Spain I´ll invite you to some gallons of beer.
Thanks!!
g.gabba
PostPosted: Sun Sep 02, 2018 5:20 am    Post subject:   Reply with quote  Mark this post and the followings unread
thx, would be a pleasure!
glhf
