Single eurorack module power supply
Page 1 of 1 [5 Posts]
Audio files: 27
PostPosted: Sun Oct 07, 2018 12:35 pm    Post subject: Single eurorack module power supply
Subject description: using a usb powered retro dcdc converter
Was in need for a power supply for a single eurorack module because when I’m developing/programming a module I don’t think it is benificial for other modules to have them powered up so often.
I had a dcdc converter in my box of goodies, input 5volt and out 12volt pos and neg, capable of supplying around 2x40mA (1 watt) which is enough for most modules.
my synth
Audio files: 34
PostPosted: Mon Oct 08, 2018 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool little tool Smile
I have a Mutable Module Tester lying around, I don't use it as often as I should. (It can supply test signals, and analyse (to a degree) module output signals.)
LFLab
PostPosted: Mon Oct 08, 2018 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Reliable DCDC converter too, it says so on top! Very Happy
Audio files: 27
PostPosted: Mon Oct 08, 2018 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
And it is!
Lots of DC/DC converters give out a higher voltage when unloaded, this one doesn't Very Happy
my synth
ixtern
PostPosted: Tue Oct 09, 2018 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
And what noise this DC to DC module produces on +-12V lines? Low enough under load?
