BassMaster 85
Page 2 of 3 [60 Posts]
Hammer
Audio files: 20
PostPosted: Mon Aug 13, 2018 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, ixtern!
I will post here some of my tested cirsuits. Now I see, that it will be two more versions of BassMaster:
- BassMaster 74, TL074 based synth, +/- 12V;
- BassMaster 69, CD4069 UBE based synth, +/- 6V;
All of them will have the cheapest MT3608 DC-DC step up converter.
ATTiny 85 tested with exponential V/Oct table, and it's working fine. I only still can't make any good sounding LPF. It's possible to replicate Moog's transistor ladder LPF, but it's not my goal.
Here are some new circuits of BassMaster 69:
Dual power supply
 Filesize:  96.68 KB
 Viewed:  87 Time(s)
VCA
 Filesize:  112.59 KB
 Viewed:  80 Time(s)
Saw VCO
 Filesize:  104.49 KB
 Viewed:  81 Time(s)
Hammer
Audio files: 20
PostPosted: Wed Aug 22, 2018 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got carried away with sodering... BassMaster 69 is fully analog, with CV/Gate interface.
Video:
BassMaster 69 circuit diagram
 Filesize:  434.29 KB
 Viewed:  96 Time(s)
Popcorn_BMS69.mp3
 Filename:  Popcorn_BMS69.mp3
 Filesize:  1.83 MB
 Downloaded:  97 Time(s)
Audio files: 228
G2 patch files: 319
PostPosted: Wed Aug 22, 2018 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nicely simple electronics - I love that thyristor osc thing .. that must be about as simple as it can get Cool
nice tune too Wink
Hammer
Audio files: 20
PostPosted: Wed Aug 22, 2018 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
And it's incredibly stable!
BassMaster 74 will be modular. It's very hard to make all this on one small PCB.
Some photoes:
 Filesize:  1.07 MB
 Viewed:  53 Time(s)
 Filesize:  862.8 KB
 Viewed:  60 Time(s)
 Filesize:  894.69 KB
 Viewed:  52 Time(s)
Hammer
Audio files: 20
PostPosted: Fri Aug 24, 2018 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I've recode ATTiny85 USB -> CV/G converter to make glissando. Is it not necessary to have ADSR envelope driven LPF for saw bass?
sawbass_BMS69.mp3
BassMaster 69 saw bass
 Filename:  sawbass_BMS69.mp3
 Filesize:  309.34 KB
 Downloaded:  89 Time(s)
Hammer
Audio files: 20
PostPosted: Fri Aug 31, 2018 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
First attempt to make eurorack case:
 Filesize:  686.63 KB
 Viewed:  52 Time(s)
Mynasru
PostPosted: Sat Oct 13, 2018 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing sound! I may be able to design some PCBs in eagle if your interested Very Happy
BTW do you know this website:
http://robstave.github.io/acs/
It has many lo-fi attiny85 examples.
Hammer
Audio files: 20
PostPosted: Sat Oct 13, 2018 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Mynasru, thank you a lot!
I'm very interested in PCB, but I still not sure with circuit design.
I've already made new version of expo conerter, and some changes in power supply circuit. And I want to use iPhone as MIDI source. Now I've tested ESP8266 WiFi module as CV/G source for Korg Monotron, and it's working good with no audiable latency. Also BassMaster should have some another filter.
I'm wating for parts to solder and test new version of BassMaster, and then it will be great to help me with PCB.
Mynasru
PostPosted: Sat Oct 13, 2018 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Let me know when your design (Bassmaster or others) are ready and I'll try to help Wink
Hammer
Audio files: 20
PostPosted: Sat Oct 13, 2018 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thumright
Hammer
Audio files: 20
PostPosted: Sat Oct 27, 2018 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eurorack case still is too expensive for me. So, I decided to make 'tiny' rack for testing new circuits for BassMaster. Height of modules is 100mm, width 10X mm.
 Filesize:  638.5 KB
 Viewed:  41 Time(s)
 Filesize:  722 KB
 Viewed:  43 Time(s)
Hammer
Audio files: 20
PostPosted: Wed Nov 28, 2018 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
BassMaster 85 with glide feature + Sallen Key LPF in tiny rack:
Hammer
Audio files: 20
PostPosted: Tue Dec 11, 2018 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi again!
Two microprocessors are twice more fun than one!
I have tested several filters, even tried diode half ladder one. But I don't have enough knowledge to set them up well. Trials and errors...
Later I will return to the development of the diode filter (it sounds like boiling mercury, but I have still no success with resonance), and so far earned only Buchla-syle LPG.
But it works great!
First ATTiny85 is still used as signal source, and the second one is for vactrol LED controlling.
500Hz of Arduino PWM is not affect LDR. Now you do not need linear LDR because its possible to correct envelope by microprocessor. And I want to make sine modulation.
But vactrol must be fast. I ordered these vactrols: https://ru.aliexpress.com/item/FREE-SHIPPING-5PCS-LOT-VTL5C1-L5C1-DIP-4-IC-NEW-Original/32651474669.html
Are there any cheap fast nonlinear LDR or vactrols?
Also, you can just replace vactrols with 100k stereo pot, and it will be very useful for continuous saw bass like in my previous post.
Additional SYNC output is for a drum sequencer. It have its own MIDI channel.
There is still a lot of work, but it is already possible to design a PCB I think.
 Filesize:  308.44 KB
 Viewed:  42 Time(s)
BMS85_VX.mp3
BassMaster 85VX SAW test
 Filename:  BMS85_VX.mp3
 Filesize:  711.93 KB
 Downloaded:  44 Time(s)
Mynasru
PostPosted: Tue Dec 11, 2018 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice sounds!
From the beginning of February I have time to design and order PCBs. You can refine your design in the mean time, and we can discuss some options (SMD/SMT, all in one PCB/pots etc mounted separately, etc).
Wink
Hammer
Audio files: 20
PostPosted: Tue Dec 11, 2018 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
Hammer
Audio files: 20
PostPosted: Fri Dec 14, 2018 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tell me please, can I use CA3080 with 5V single supply?
Audio files: 228
G2 patch files: 319
PostPosted: Fri Dec 14, 2018 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Barely so I think ... but depends ... output voltage swing seems limited to about 1.5V from the rails .. so that looses 3V .. leaving about 2V output swing at 5V. But voltage range minimum is specified as -2V/+2V .. so it should work at least.
Also it will need some biasing when operating on a single supply .. which may get a bit tricky with it's low-ish input impedance (like 10k worst case it seems) .. could use a regulator like construction to make the virtual ground at Vcc/2 to solve that.
But maybe you can get away with these limitations ... when you can deal with a 2Vpp output excursion around Vcc/2 .. by maybe adding an opamp after.
Hammer
Audio files: 20
PostPosted: Sat Dec 15, 2018 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I will think.
JovianPyx
Audio files: 212
PostPosted: Sat Dec 15, 2018 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
The two schematics found here:
http://electro-music.com/forum/post-436089.html#436089
are my design and I never tested them. Psyingo wanted to try them and found some weirdness for which he made modifications and said he made it work better. I don't know what he did and didn't get a copy of his schematic, so be warned, it may take some fooling around to get it to work. If I were to try it, I'd start with the upper and then the lower.
Time flies like a banana.
corruptio optimi pessima
Hammer
Audio files: 20
PostPosted: Sat Dec 15, 2018 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tried this schematic: http://www.experimentalistsanonymous.com/diy/Schematics/Filters%20Wahs%20and%20VCFs/4007%20Based%20VCF.pdf
CV range occurred to be quite unuseful(
The last attempt will be to use digital potentiometers. And if the attempt turns out to be unsuccessful, then I will more accurately select the vactrols.
Hammer
Audio files: 20
PostPosted: Sat Dec 15, 2018 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I havn't 4007, but I have k3446 MOSFETs:
https://www.datasheetspdf.com/pdf/656449/RenesasTechnology/K3446/1
May be try k3446...
JovianPyx
Audio files: 212
PostPosted: Sat Dec 15, 2018 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I designed with 4007 and 4069 in non-digital mode just to see if it will work, did several things that didn't work perfectly but were useful anyway, like saw to triangle with BS sine output (for a Fatman). I view the 4007 as a CMOS transistor array with 3 of each P and N types, sorta connected usually conveniently. Cool
Hammer
Audio files: 20
PostPosted: Sun Dec 16, 2018 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I understand that, and it's great! And I always check such schematics. And I often sketch what I have checked. That's why I've been doing my synth for so long Laughing
I tried the second circuit with a stereo pot. instead of transistors, but I really did not like the sound of resonance. I have little experience, perhaps the input signal was high amplitude...
That's what I got:
 Filesize:  89.2 KB
 Viewed:  22 Time(s)
Hammer
Audio files: 20
PostPosted: Sun Dec 16, 2018 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I checked the digital potentiometers. I have only x9c103, it is 10k. It's not cover full cutoff range. Need to use x9c104 I think:
https://www.intersil.com/content/dam/Intersil/documents/x9c1/x9c102-103-104-503.pdf
I can't hear any audiable clicks from fully breadboarded circuit. Maybe some hiss sound, but this is breadboard...
Using two analog oscillators it is possible to make an ADSR circuit without using a microprocessor. On the contrary, you can use a very small microprocessor, such as Attiny 10 for decay circuit.
BMS85_VX9.mp3
 Filename:  BMS85_VX9.mp3
 Filesize:  344.4 KB
 Downloaded:  33 Time(s)
BMS85_VX9_2.mp3
 Filename:  BMS85_VX9_2.mp3
 Filesize:  313.34 KB
 Downloaded:  31 Time(s)
Hammer
Audio files: 20
PostPosted: Mon Dec 17, 2018 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
JovianPyx, I've tested the 4069 state variable filter with k3446 MOSFETs. Filter closed at ~3V on MOSFETs gates, and opened on ~3.5V
I think it is possible to use level shifting op amp to get CV range closer to 0-5V.
