Pursuing Karplus-Strong
Page 2 of 2 [34 Posts]
Goto page: Previous 1, 2
Audio files: 27
PostPosted: Thu Dec 06, 2018 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy I learned machine code on a self made "machine" built around the HD64180
I even had it sampling audio under dma, a video interface, a soundboard with a AY38910 all written in machine code.
Then I got the Junior computer around the 6502 and then a REAL computer: the Acorn Atom (also 6502 based)
Yup, same age as you salut
my synth
JovianPyx
Audio files: 218
PostPosted: Thu Dec 06, 2018 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
As an addendum - There is a way to possibly speed up the low pass IIR filter which also eliminates the need for the b1 variable:
The formula can be rewritten algebraically as:
Code:
z = z + a0 * ( in - z )
Time flies like a banana.
corruptio optimi pessima
JLS
Audio files: 27
G2 patch files: 280
PostPosted: Sat Dec 29, 2018 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Update Arduino Karplus-Strong.
- better triggering
- better timers (PWM PIN 11)
Example Simple Karplus-Strong and duophonic Karplus-Automata cellular automata sequencer Smile
Karplus_Strong.ino
 Filename:  Karplus_Strong.ino
 Filesize:  1.74 KB
 Downloaded:  70 Time(s)
Karplus_Automata.ino
 Filename:  Karplus_Automata.ino
 Filesize:  2.86 KB
 Downloaded:  63 Time(s)
Sorry my bad English Smile
MapacheRaper
PostPosted: Sat Dec 29, 2018 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool! I´ll be testing it in no time. Thanks!!
JLS
Audio files: 27
G2 patch files: 280
PostPosted: Sun Dec 30, 2018 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Floating point version Arduino Karplus-Strong.
- better sound
- better lowpass filtering
- but needs more memory and cpu resources
Karplus_Float.ino
 Filename:  Karplus_Float.ino
 Filesize:  2.64 KB
 Downloaded:  61 Time(s)
JovianPyx
Audio files: 218
PostPosted: Sun Dec 30, 2018 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
- better sound
This is why I use STM32 ARMs. The better ones have single cycle float multiply and float add (from a hardware FPU), they have a lot more SRAM and they are a lot faster. There are also several DSP instructions including square root and MAC. Still can use C, but the environment is different if you move away from the arduino compatible chips. If gcc is given the correct optimization strings, it will use DSP instructions where possible (which speeds things up). STM32H7 for example runs at 400 MHz and has 1 megabyte of internal SRAM (though not all of it is contiguous, there is a 512 kbyte contiguous piece).
I use a completely free set of tools, though there's some initial angst in setting it all up. gcc needs to have stuff added so that it can cross compile. There are also GUI based environments (like Eclipse), but I found those to be confusing, tedious and non-intuitive. My typical work cycle is
1) edit source with my favorite text editor
2) issue a make command to compile the code
3) send the binary to the ARM and test.
4) repeat as necessary.
The arduino platform is great for learning about microcontrollers, but while it does things that might make coding easier - they also make the code slower. Those constrictions go away when you leave the arduino world and once you learn how to do things the non-arduino way, you'll be able to use any processor out there not just those in the arduino developer world.
MapacheRaper
PostPosted: Mon Dec 31, 2018 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That floating point version seems really cool JLS. Im diying to test it. Thanks for sharing!
@Jovian, yepp, after some weeks playing with the arduino I see you are totally right. It is more intended for gating/triggering, sequencing, etc, but for DSP it needs way more meat (even if you can do some cool tricks too, even complete oscillators)
Jovian, has you taken a peek at the ESP8266 and ESP32 chips?. It packs a lot of power and bang for the buck. Definitively I think we will see some next gen O_C and mutable type of things coming from this chips
JovianPyx
Audio files: 218
PostPosted: Mon Dec 31, 2018 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had not seen the ESP chips. I don't need the wifi tho. I've had really good experience with the STM32 stuff, so I'll stick with that. Dual core is nice, but troublesome to get 2 cores cooperating usefully (parallel processing). For synth projects, a fast single core CPU is far less bother IMO. I've written multithreaded polysynths for a raspberry pi3 and that code still has issues regarding coordination of threads and memory sharing.
MapacheRaper
PostPosted: Mon Dec 31, 2018 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have never done multithread, but I have meditate about it and it looks like a pain in the ass, yes. But we like it or not it´s what the future brings. It seems like 3-4GHz is the max speed that silicon does and the current state of the art chips are growing in parallel giving more and more multitreads.
So I guess somehow code will adapt to that, maybe facilitating or even completely inmaskaring in in the framework (so the framework do all the heavylifting transparently for the coder)
Regarding ESP, I see it with a lot of potential. Imagine the Ornament and Crime. Probable the more succesful open source module in existence. All people using it. A ESP version could use the wifi to connect with the smartphone/computer, so suddenly you have snapshots of the patches (infinite patches memory) plus you can control the secuencers and whatnot from the phone. And run different algoridms in every channel, something that most users ask but is quite difficult to implement in the module now.
And all this in a chip that costs 2-3USD instead of the 20-30 of the teensy.
Interesting times, for sure. I guess we will have a new wave of completely new functions in modules, no seen yet, in no time, as people start to hack with the ESP and find his treasoures
With that said, I have some SMT32 arriving in the next days too. Yumm
