sMs SN Voice Build
Page 1 of 1 [3 Posts]
matinnin
PostPosted: Tue May 15, 2018 7:20 am    Post subject: sMs SN Voice Build
Subject description: built and done - ? Mixer select A - C
edit: i've looked a little deeper and see it will do it, i just need to figure out how to switch it between on/off on pin 25/26/27
i've finished my first sMs board SN voice Build, MOTM style. the default setup for the output is Either Noise or Pulse. I was somewhat expecting this Voice would mix the pulse and the noise? the documentation shows a 10k output pot , which is not on the MOTM panel, i paneled mine to emulate the MOTM panel available.
i'm wondering what the referenced Mixer select A , and Mixer select C are for? my switch(S2) is J2-6 , which outputs to J3-1 ,
does either of these mixer sel options mix noise and pulse? or what do they do?
thanks,
https://www.youtube.com/watch?v=yIrfZYETt5Y
PostPosted: Fri Dec 28, 2018 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
This should clarify things.
Bill
 Filesize:  196.01 KB
 Viewed:  168 Time(s)
Twin-X
PostPosted: Fri Feb 21, 2020 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
i have finished my pcb (finally after 8 years of owning the board...)
However i am struggeling with the frontpanel, i have a MOTM system (which seems to be rare these days) and i found https://modularsynthesis.com/mrmrshoes/sn-voice/sn-voice.htm
It was the only motm fpd i could find. Yet it looks great and the mixer looks like a very nice addition. However i have no clue how to do the wiring from the sMs board to this panel.
I did find the extra mods. But i am stuck with the switches for mixer selection. How to attach them to j3-1 j3-11 and j3-12 or is this not possible with the sms pcb?
Thanks in advance.
