  PHOBoS & Friends Waxing Giddiness
 Forum index » DIY Hardware and Software » The Repair Shop
{solved} What's wrong with my op amp buffer??
Page 1 of 1 [6 Posts]
Beaufays
PostPosted: Fri Dec 28, 2018 9:10 am    Post subject: {solved} What's wrong with my op amp buffer??
Subject description: something strange is going on with the simplest of opamp buffer circuits
Hey,
I'm was building a buffered multi and noticed something strange on the outputs, so I went and breadboarded the simplest non-inverting buffer schematic, and look what I get... I'm at a loss here...I used tl072 and tl074 and both give the same output...
what am I doing wrong? is this because I buy the cheapest opamps on ebay? Confused
buffer problem
 Filesize:  399.66 KB
 Viewed:  84 Time(s)
JovianPyx
Audio files: 218
PostPosted: Fri Dec 28, 2018 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
It looks like the positive portion of the signal is being clipped just above zero volts. Measure Vss and Vdd at the opamp power pins. It's possible that a bad connection prevents the full positive voltage from entering the opamp. I'm assuming that this circuit is driving nothing. If it's driving some circuit, disconnect the load and measure the waveform again.
I can't say that it won't or doesn't or can't happen, but a bad opamp is probably not the problem. If you have known good opamps, try one of those to be sure.
I won't buy electronic parts from e-bay. But then I always avoid e-bay because I just don't trust it. It is possible to get cheated, but your milage may vary.
Time flies like a banana.
corruptio optimi pessima
Beaufays
PostPosted: Fri Dec 28, 2018 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, yeah the circuit is not driving anything, but that doesn't seem to affect it anyway..
will measure power input, and buy some chips at the local shop to compare.
thx
Audio files: 27
PostPosted: Fri Dec 28, 2018 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
That’s hard to tell because the scope is set at ac, so the voltage could be positive, negative or around 0volt.
my synth
JovianPyx
Audio files: 218
PostPosted: Fri Dec 28, 2018 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree that there's no way to guarantee that the OP set zero on the scope properly, however it is standard practice for some of us. There is most definitely clipping going on there. One of the simplest ways to account for clipping in this extremely simple circuit is for a supply line to be severely degraded with resistance or disconnect. It was only this intuition that caused me to suggest what I did. And I did not rule out a bad opamp, a blown output driver transistor could cause this as well.
Beaufays
PostPosted: Sat Dec 29, 2018 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
hey,
think I found the problem. setting the scope to DC showed me the OSC was oscilating at around 12V... hence the clipping...
thanks for helping look in the right direction! Wink
