 Forum index » Instruments and Equipment » Nord stage
Stage 2 encoder repair
jazzsaxe
PostPosted: Fri Jan 25, 2019 2:52 pm    Post subject: Stage 2 encoder repair
Subject description: piano and synth encoders (knobs) functioning poorly
The knob in the synth section that lets you scroll through sounds barely functions...multiple turns to advance one or two sounds at a time. The "main" encoder in the piano section functions less than optimally (not as bad) but not perfectly. Should I try to repair myself (I can solder). If not, where in the Chicago area can I get these fixed. Thank you, Peter!
