OSC OSCar synth not starting
wahee
PostPosted: Sun Jan 27, 2019 2:58 pm    Post subject: OSC OSCar synth not starting Reply with quote  Mark this post and the followings unread
My rather nice OSCar synth started to make some strange noises whilst on and then died.
I just get all the octave LED's lit up but most times nothing.
If I use the keyboard every 8 note makes an octave LED light up and the space button will light a LED also.
No sound
So I have:
checked the +5/-5v power rails. All good
checked battery voltage OK at 3.4v
checked the keyboard and power ribbon cables for continuity, all OK
Rewired the control board and voice board interconnects with new quality connectors
checked the continuity of sockets with the piggy back MIDI board, all OK
checked practically all the 40 and 74 logic IC's with a tester.
Swapped out the 6116 RAM x2 for known good, no change.
checked the clock on the ADC and there is a square wave present on the scope, so seems OK
but I still have no luck
I have checked the Z80 with a scope and it seems lifeless,so swapped it for a known good. But again no luck.
I suspect the reset circuit. Should I see something on the output of this circuit when the synth is first powered up?
is there anything else I can try as this synth seems relatively simple but has thrown me.
Embarassed
