Confusion about the polarity of LFO output
Page 1 of 1 [8 Posts]
kaputtpanzer
PostPosted: Mon Jan 28, 2019 12:48 pm    Post subject:  Confusion about the polarity of LFO output Reply with quote  Mark this post and the followings unread
Yesterday I built a multiwave lfo on breadboard. My design is based on a lfo circuit (that is powered by a bipolar psu) that i found somewhere on the web. I think Phobos and also Ray Wilson came up with a similar design. I powered the lfo by a 78L09 regulator and I needed to change a few things here and there. Now the schematic looks almost like this:
The lfo is running very well so far. I used my scope to check the output waveforms and everything was looking alright. But there was one thing that was really bothering me. I thought the lfo would oscillate in a 0 to 5V range but instead of this, it was oscillating between -2,5V and +2,5V. I connected the red lead of the scope probe to the coupling capacitor at the triangle output and the black lead to ground pin of the regulator.
So how is it possible to measure a negative voltage at the output? Is it really a negative voltage or did I just measure it wrong? It is the same with my multimeter btw.
[... Embarassed Twisted Evil ]
Any ideas on the negative-voltage-with-positive-power-regulator thing?
 Filesize:  1.07 MB
 Viewed:  50 Time(s)
 Filesize:  195.08 KB
 Viewed:  52 Time(s)
Audio files: 27
PostPosted: Mon Jan 28, 2019 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
the output of the triangle waveform is coupled by a capacitor, which removes dc hence you end up with an ac voltage.
measure before the 10uF cap and you measure dc.
my synth
Audio files: 230
G2 patch files: 319
PostPosted: Mon Jan 28, 2019 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've deleted some spirals here.
MapacheRaper
PostPosted: Tue Jan 29, 2019 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
The neutron should be capable of accepting anything from+10 to -10 without blowing up, as any eurorack gear.
Probably the neutron fail is not related to your LFO, it´s just a coincidence... It´s a pity, but Beh will proabably give you a new one. Just dont comment them about your LFO... Wink
kaputtpanzer
PostPosted: Thu Jan 31, 2019 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply. Yes I know that, I put the capacitor to the output to get rid of the dc offset voltage Laughing But it seems I have a lack of knowledge regarding measuring ac voltages. I just was confused why there is a negative voltage, when I use 0V as reference point with a single supply lfo. I just didn't understand why there is a lower value then 0V when measuring in dc mode.
kaputtpanzer
PostPosted: Thu Jan 31, 2019 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the neutron was acting a bit strange after the last firmware update. I don't think it has anything to do with my "low voltage lfo" Razz it is weird, because the VCF stopped working with the envelopes and even with the VCA bypassed, but it was still working with the internal LFO Rolling Eyes Otherwise no sound from the VCF, nothing. It felt a little bit like a weird software issue or that i somehow disabled the VCF with a secret keypress Laughing
Hashtag Octothorpe
PostPosted: Fri Feb 01, 2019 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Without the capacitor in there to "get rid of the DC offset voltage" the average DC voltage coming out of a 5V peak-to-peak oscillator would be +2.5V, right? Even though it's oscillating and would seem to be not DC....... but there is an offset.
So when you toss a capacitor in the signal stream, you're taking that "offset" of +2.5V and making it 0V, so anything below that is negative.
The DC-blocking capacitor is "sucking" current back from the output, and that's where the negative voltage is coming from. If you take the 10uF cap and the 47K resistor away from the output of the final op amp, you should get the values you're looking for.
kaputtpanzer
PostPosted: Thu Feb 07, 2019 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh man, haha I finally got it Embarassed well that was actually so obvious, but it totally confused me. Embarrassing Laughing . Thank you very much!
