today> Twyndyllyngs Live - special shelter in place episode with Ninjam Chez Mosc
"poly" MIDI clock ?
Page 1 of 1 [6 Posts]
chapelier fou
PostPosted: Tue May 14, 2019 12:51 am    Post subject: "poly" MIDI clock ? Reply with quote  Mark this post and the followings unread
It's my first post here, so Hi !
When I drive a sequencer with a square LFO (in poly mode), the sequence is actually polyphonic.
But I'd like the sequence to be sync with an external clock.
The "Clock" module found in the LFO section doesn't seem to allow a polyphonic use.
Am I right ? Any help how to achieve this ?
Thanks !
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed May 15, 2019 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
LFOB has a Clk mode, just keep pressing the button above the rate knob.
In this mode the output will sync to a multiple of the midi clock (external or internal).
A sequencer in the voice area of a poly patch is only kind of polyphonic though.
chapelier fou
PostPosted: Wed May 15, 2019 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I totally missed this option, great !
I'm curious, would you care to explain what are the limits of "polyphonic sequencing" ?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed May 15, 2019 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
All the G2 sequencers are monophonic. If you put one in the voice area of a poly patch set to play 8 voices, you just get each voice transposed by 8 identical sequencers (not counting tricky patching with the status module and switches). If you use multiple sequencers in a mono VA/FX that control a poly patch in another slot via midi, that might be the most productive technique.
It can get a little nuts though.
chapelier fou
PostPosted: Wed May 15, 2019 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
That one of the reasons why i bought a G2. I'm in love with the "gated sequencers" of the Prophet Rev2.
I'll check your patch, thanks !
chapelier fou
PostPosted: Thu May 16, 2019 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
This patch is quite insane.
I'm still trying to figure out the chaining system of sequencers. I'm not 100% sure of what I'm doing and sometimes, when messing with sequence lengths, the whole sequence stops playing.
Any tutorial somewhere to properly get the chaining concept ?
I find the manual to be lacking an example.
