Troubleshooting Yusynth Minimoog modules
Page 1 of 1 [4 Posts]
sterio
PostPosted: Fri May 24, 2019 3:22 am    Post subject: Troubleshooting Yusynth Minimoog modules Reply with quote  Mark this post and the followings unread
Hey,
I'm building YuSynth minimoog VCF clone, but I have issues troubleshooting my module. I don't have any signal at the output. In fact, the signal the signal only reach the ouput of the U3b op amp. Then on the other lead of R6 (the first is connected to U3b's output), the signal is divided by 20. Then at the input of the differential pair I have no signal left, only DC.
The DC values on the pins of the differential pair U1b are really strange:
1: 2,5V
2: 0
3: 600mV
4: 10V
5: 10V
Here is the schematics
that you also can find here:
http://yusynth.net/Modular/Commun/MOOGVCF/Moogfilter-sch.jpg
Do you have any idea about what could be failing ? I spent countless hours trying to fix this issue and I can't think of what could be the problem. I doubled check every solder, components value, replaced U1 by another CA3086.
Oh, and the input is line signal from my Minibrute: it is more or less 2V peak to peak.
Thanks ! Laughing Laughing Laughing [/img]
PostPosted: Sat May 25, 2019 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Temporarily disconnect the emphasis pot and see if that changes anything. Also, look for solder bridges that are inadvertently grounding your signal. Your 2v input signal is a bit on the low side, too.
Good luck!
sterio
PostPosted: Mon May 27, 2019 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks ! I'll try that !
sterio
PostPosted: Mon May 27, 2019 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately, disconnecting the emphasis pot didn't change anything. I double checked each and every solder joint, and looked for shorts but didn't find anything.
Also on pin 4 of the CA3086, I do have a very low signal in addition to the DC offset
