 Forum index » Discussion » Introduce Yourself
Noob looking to build syths
Page 1 of 1 [12 Posts]
pix retro
PostPosted: Wed Jun 12, 2019 5:33 pm    Post subject: Noob looking to build syths Reply with quote  Mark this post and the followings unread
Hey peeps...
Im looking to learn to build some synths to complement my retro music set up.
Currently interested in some kind of drum sequencer
Musical tastes are varied so still haven't found my sound yet but aiming for a heavier sort of chip tune
Built guitar pedals in the past and repair old computers so can follow schematics but hoping to learn more and be able to design my own stuff
I've a couple of mutable instruments boards to build but I'm still learning smd soldering so haven't braved it yet... Lol
Expect plenty of questions and stupid ones at that...
Point me at the schematics!
vladosh
Audio files: 12
PostPosted: Fri Jun 14, 2019 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
hello pix retro and welcome !
you can find schematics here http://electro-music.com/wiki/ ,and also other stuff in forum ,make sure you check the luneta subforum for good circuits for practice .
cheers
vladosh
pix retro
PostPosted: Fri Jun 14, 2019 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply and the link!
Any suggestions on where to start?
gabbagabi
PostPosted: Fri Jun 14, 2019 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
to start: i would suggest a simple relaxation oscilator as lfo.
would give you with a dual opamp a buffered rectangle wave
with a quad opamp buffered rectangle and triangle-alike & inverted triangle-alike
or
with a quad opamp buffered rectangle and saw alike & inverted saw alike
will be handy for the rest of your live for giving you gate`n`clock`n`modulation`more
pix retro
PostPosted: Fri Jun 14, 2019 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tips... Gonna start having a search through the schematics to see what I've got parts for and what would be a good starting point.. should maybe do one from each category you suggested... Build up my collection from there... 😁 I've a mutable instruments module tester I'll build first and then start on the modules... Just so I don't blow everything up straight away... Looking forward to starting now!!
Audio files: 34
PostPosted: Sat Jun 15, 2019 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Minor, but it would also pay to decide what overall format you're going to go for.
If you want to build a modular, then decide on the format. Homebrew (like vladosh, or LookMumNoComputer), or Eurorack, or Moog/Dotcom format.
gabbagabi
PostPosted: Sat Jun 15, 2019 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
also importand what kind of power supply you are going to use
you would like to buy pcb/kits or you would like to do it on your own?
vladosh
Audio files: 12
PostPosted: Sat Jun 15, 2019 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
very importan if you plan on buying kits ,if so - then it's good earorack ,if you plan on more diy approach then 4U and 5U is very good as it gives you more space
pix retro
PostPosted: Sat Jun 15, 2019 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably a DIY through hole to start with... I'd like to move on to smd stuff and creating tiny boards... But that's way down the line... For power supply I've seen a couple of options... There is a frequency central board for cheap quick I'll probably use to start with and as I build up the dopfer ones look the easiest to sort..
As for size I'm actually tempted to do a look mum no computer approach as you can pick up aluminium sheets much much cheaper if they are say 200mm X 100mm... Again that's just to start with.. my aim is to keep things as low cost as possible until I know what I'm doing... 😁 Or at least have more of a clue!
vladosh
Audio files: 12
PostPosted: Sat Jun 15, 2019 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
just don't buy the cheapest pots so you might think your build is not working.. take good care of distro boards in your system or it will give you headache later with wiring ,as for smd i do it only when i have to , i got some cheap CA3080 in smd that work fine so i solder only stuff like that in SMD ,rest is thru hole
pix retro
PostPosted: Sat Jun 15, 2019 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
i will make sure to get good pots!!
the smd idea was to see if i could make a mini rack sort of think... will be waaay down the line other than the 2 boards i've got now...
keep the tips coming!!! Very Happy
Audio files: 34
PostPosted: Sat Jun 15, 2019 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd say look into the SMD thing once you are consistantly getting good solder joints every time.
