32 x 1 and 16 x 2 Channel Analog Sequencer
Page 1 of 1 [5 Posts]
Moevot
PostPosted: Wed Oct 16, 2019 8:15 pm    Post subject: 32 x 1 and 16 x 2 Channel Analog Sequencer Reply with quote  Mark this post and the followings unread
Hello. I'm having trouble getting the clock signal. When testing in steps 3 and 4 - When R54 (Clock Rate) is set for highest rate (R54 essentially shorted) clock signal should appear at pin 12 of IC13-F.
Clock should appear at pin 10 of IC13-E. On pin10 instead of clock I have 10v and on pin12 0v. After pressing the Start button, the capacitors C16, C17 charge and hold voltage all the time, the clock signal is not discharged and triggered. After a manual short-circuit of the capacitors and a voltage drop, a clock pulse is triggered, but the capacitors do not recharge.
The Step button works correctly.
CD40106 replaced twice.
Audio files: 29
PostPosted: Wed Oct 16, 2019 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome to the forum!
I'm guessing you will receive more answers if you add a circuit diagram to your post or at least a link to it.
my synth
Moevot
PostPosted: Thu Oct 17, 2019 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Problem solved. Damaged CR13. The whole came alive and works great. I recommend building this beast Smile
Audio files: 255
PostPosted: Thu Oct 17, 2019 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
flagada
PostPosted: Fri Oct 18, 2019 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
And a beast it is! I did it on stripboard, took me quite a while. Especially the panel with 32 pots, switches and LEDs.
I modded it to make it external clockable, which was quite easy using one or two of the unused schmitt triggers.
