today> Cancelled - Sorry Chez Mosc
Jörgen Bergfors LM13600 VCA +/-12V
Page 1 of 1 [4 Posts]
buildamodular
PostPosted: Fri Oct 20, 2017 2:24 pm    Post subject: Jörgen Bergfors LM13600 VCA +/-12V Reply with quote  Mark this post and the followings unread
Do i need to change any resistor values to make it work correctly with +/-12V? As im assuming it is intended to work with +/-15V.
 Filesize:  88.9 KB
 Viewed:  395 Time(s)
vladosh
Audio files: 51
PostPosted: Sat Oct 21, 2017 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
it will work fine with 12V too i'm sure ,it's a good vca ,have one of these in my synth Smile
cheers
Brogram
PostPosted: Fri Nov 01, 2019 11:34 pm    Post subject: Run on +12v only? Reply with quote  Mark this post and the followings unread
Is it possible to change this VCA to only run on +12v or +9v?
Or do ya'll know of another VCA design based on the LM13700 which can do so?
mph
PostPosted: Sun Nov 03, 2019 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
a simple way to create a bipolar supply is to use an inverter like the LT1054.
Feed it with +12VDC and you'll get -12VDC from the LT1054.
http://www.ti.com/lit/ds/symlink/lt1054.pdf
