wahee
Posted: Sun Jan 27, 2019 2:58 pm Post subject:
OSC OSCar synth not starting |
My rather nice OSCar synth started to make some strange noises whilst on and then died.
I just get all the octave LED's lit up but most times nothing.
If I use the keyboard every 8 note makes an octave LED light up and the space button will light a LED also.
No sound
So I have:
checked the +5/-5v power rails. All good
checked battery voltage OK at 3.4v
checked the keyboard and power ribbon cables for continuity, all OK
Rewired the control board and voice board interconnects with new quality connectors
checked the continuity of sockets with the piggy back MIDI board, all OK
checked practically all the 40 and 74 logic IC's with a tester.
Swapped out the 6116 RAM x2 for known good, no change.
checked the clock on the ADC and there is a square wave present on the scope, so seems OK
but I still have no luck
I have checked the Z80 with a scope and it seems lifeless,so swapped it for a known good. But again no luck.
I suspect the reset circuit. Should I see something on the output of this circuit when the synth is first powered up?
is there anything else I can try as this synth seems relatively simple but has thrown me.
Regebro
Posted: Thu Jan 16, 2020 4:23 am Post subject:
Late answer, but that's exactly how they behave when the battery is dead. |
Regebro
Posted: Fri Jan 24, 2020 5:39 am Post subject:
To be clear, they behave like this even AFTER the battery has been recharged/reset. Booting multiple times usually gets by pure luck, to a place where LEDs blink. The fastest thing to do then is to load a memory dump over MIDI.
You can also press the "Panel" button, and then twist every single knob. This usually gets things into a more reasonable mode. Then save the current settings to every single memory.
Reboot, and you should be in business.
However, I read a few days ago, that if it continues to not boot properly, then yes i can be the reset circuit, and the solution is apparently to pull extra power lines directly, which seems like a hack... |
citygas
Joined: Feb 10, 2020 Posts: 3 Location: irland du nord noir
Posted: Sat Apr 04, 2020 4:18 pm Post subject:
Long time gone..
Any joy?
I just fixed my deloren synth..hope your one is going again, so bad yet so good design |
Regebro
Regebro
Posted: Mon Oct 12, 2020 5:28 am Post subject:
Re: OSC OSCar synth not starting |
wahee wrote: | I suspect the reset circuit. Should I see something on the output of this circuit when the synth is first powered up? |
As a headsup, Bob Grieb has made a new daughterboard for the OSCar, so that he could put in larger ROM's, to add features like CC control etc. I got a copy to beta test recently, and realized that he has incorporated a little IC called MCP100-460DI/TO or MCP100-475DI/TO
https://www.digikey.com/en/products/detail/MCP100-475DI%2fTO/MCP100-475DI%2fTO-ND/275213?itemSeq=341347278
That's simply a little IC that holds the reset low until the power has stabilized. I don't know how to integrate it in the standard OSCar circuit boards, but in the new one, as far as I can tell, you can bypass the normal reset circuitry and use this one instead.
This could solve your startup problems.
His software changes also include detection of memory loss, so that you no longer have to switch on and off the OSCar after memory loss hoping that it randomly will boot.
More info here: http://tauntek.com/OSCar.htm
Also, we are discussing this on the mailing list above. |
