Dry/Wet Control Schematic
Page 1 of 1 [7 Posts]
TekRa
PostPosted: Tue Jan 28, 2020 9:31 pm    Post subject:  Dry/Wet Control Schematic
Subject description: FX amount selector
Hey,
If i have a wet signal from an fx chain and a parallel dry signal, how do i go about designing a dry/wet control ckt for the same.
My keywords seems to be weird so unable to find on Google.
Thanks,
Shiv
PostPosted: Tue Jan 28, 2020 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Juanita Moore recently made a video about diy building a reverb module.
Youtube: https://youtu.be/1I3db1TwfEk
Using this schematics: https://drive.google.com/file/d/1UECoI_JlwZcMkhOlTTOBQnz6PQ_TMQOb/view
Wich has a good example for a dry/wet mixer.
my synth
Boerge
PostPosted: Thu Jan 30, 2020 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
You can find a nice dry/wet control by Jürgen Haible's PS3000-clone:
http://www.jhaible.info/polykorg/jh_3200_signal_3of4.gif
(lower part of the schematic)
Works with vactrols, with one pot for each you can mix the dry/wet signals from the resonator section and the chorus ensemble. The control voltage generation you can find here:
http://www.jhaible.info/polykorg/jh_3200_signal_2of4.gif
HTH
Boerge
...ich will doch nur löten...
vladosh
Audio files: 51
PostPosted: Tue Feb 11, 2020 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
if you want cv controlled dry/wet module you can make this vc aux http://electro-music.com/forum/post-436124.html
kaputtpanzer
Audio files: 15
PostPosted: Fri Feb 21, 2020 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are looking for something simple you could try this. You can replace the JFET with an NPN or with a non-inverting opamp buffer. I built similar circuits for dry/wet mixing several times, they work as expected.
Buff n Blend:
Electric Druid
PostPosted: Sun May 31, 2020 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
This page is the one you want:
http://www.geofex.com/Article_Folders/panner.pdf
The circuit in the box in the middle-left of the first page does exactly the wet/dry mix you're looking for.
HTH,
Tom
Electric Druid Synth and Pedal DIY website
PostPosted: Mon Jun 01, 2020 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Electric Druid wrote:
This page is the one you want:http://www.geofex.com/Article_Folders/panner.pdf
This is great for future designs... thanks for sharing 😀👍🏻
my synth
