Soundlab Ultimate/Expander build question.
Page 1 of 1 [5 Posts]
MartianModular
PostPosted: Mon Mar 02, 2020 11:17 pm    Post subject: Soundlab Ultimate/Expander build question. Reply with quote  Mark this post and the followings unread
Hello all,
I'm on a couple of other synth DIY forums, so if you've already seen this inquiry, please excuse the cross-post.
I'm in the process of troubleshooting my recent MFOS Soundlab Ultimate and Expander build. I've worked through a number of issues, and the synth is functioning well, with a couple of notable exceptions.
Currently, I'm tackling a misbehaving VCO1. It exhibits a slightly shaky characteristic on sustained notes. I would describe it as "jittery". Scaling and overall pitch stability is excellent.
The other two oscillators also have this slight random jitter, but it's subtle. Totally usable.
On VCO1, this jitter can be heard from all outputs, and directly off the output pin of U2.
I've replaced U1, U2, the 100k coarse tuning pot, C7, Q1, upgraded and replaced C4 and C10 decoupling caps with 2.2uf bipolar electrolytics, and replaced the 3904's with a new matched pair.
Any suggestions from other Soundlab builders?
Audio files: 29
PostPosted: Mon Mar 02, 2020 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you'd add a schematic or at least a link to that, would increase the relevant answers dramatically...
Just sayin' Rolling Eyes
Other that that: welcome to this forum
my synth
MartianModular
PostPosted: Tue Mar 03, 2020 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Here's a link to Ray's circuit description and schematic. If you click on the description for VCO1, a schematic is included.
http://musicfromouterspace.com/forums.html?CATPARTNO=&PROJARG=SOUNDLAB_ULTIMATE%2Fpage2.html&MAINTAB=SYNTHDIY&SONGID=NONE&PLAYONLOAD=FALSE&VPW=&VPH=&CATMOBISTATUS=&SYNTHDIYSTATUS=CONTENT&SEARCHTERM=
MartianModular
PostPosted: Tue Mar 03, 2020 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Just in case the link doesn't cooperate, here's the schematic.
VCO1
 Filesize:  25.57 KB
 Viewed:  14 Time(s)
MartianModular
PostPosted: Wed Mar 04, 2020 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I moved the Soundlab into the studio and recorded three tracks. All direct out from the individual oscillators. There is a bit of jitter on oscillators 2 and 3, but VCO1 is the worst, by far. Three links to follow.
https://drive.google.com/file/d/11WJbWks0HotsIrDLlCZlgljTxGUzXtVF/view?usp=drivesdk
https://drive.google.com/file/d/1JDj4-et9mHmKLc4_LJthpNPMkskydiC3/view?usp=drivesdk
https://drive.google.com/file/d/1yBXiuvCesThN81y0JMxrEPtYj-PiD_ko/view?usp=drivesdk
