"Mono" envelope on Polysynth ?
Page 1 of 1 [6 Posts]
chapelier fou
PostPosted: Tue Jun 23, 2020 12:24 am    Post subject: "Mono" envelope on Polysynth ? Reply with quote  Mark this post and the followings unread
Hi there,
The forum here seems super quiet, but how knows, maybe I could find some help here anyway ?
I'm trying to emulate my Korg Delta, where the amplitude envelope has a "Single" trigger mode. In this mode the envelope triggers only on the first note.
How do you replicate this behavior on the G2 ?
Audio files: 251
PostPosted: Tue Jun 23, 2020 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you could use the Gate output from the MonoKey module to trigger your envelopes.
From the help file:
Gate
This yellow output sends a high logic level (+64 units) every time a key is pressed on the keyboard or a midi note-on is received at the Midi In port. The logic signal switches back to a low logic level (0 units) when the last key is released. You can use this signal to start envelopes in the single-trigger fashion. If a sustain pedal is activated, the logic signal will be high for as long as the pedal is pressed. Signal: Logic.
So it seems to stay active for as long as at least one note is being played, if so one could control the overall amplitude envelope from this.
And then for the poly bits you could just use the regular stuff.
chapelier fou
PostPosted: Tue Jun 23, 2020 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks ! For some reason when I use this, I hear a cluster of all the previous notes, switch to the next in a round-robin way.
Audio files: 251
PostPosted: Tue Jun 23, 2020 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. ok .. I better fire up a G2 then soon to try some stuff Laughing
But not right now - it's late.
chapelier fou
PostPosted: Wed Jun 24, 2020 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
That's very kind.
I must admit that there is something I don't get with the polyphony system. I've been running into this situation a few times.
Audio files: 251
PostPosted: Wed Jun 24, 2020 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I see what you mean .. or hear what you mean rather ... ok .. so how about something like attached then?
Maybe I just misunderstood ...
trig_single_test.pch2
test patch for single trig mode
 Filename:  trig_single_test.pch2
 Filesize:  1.3 KB
 Downloaded:  8 Time(s)
