Help needed - start on high logic
Page 1 of 1 [6 Posts]
arturmeinild
G2 patch files: 4
PostPosted: Sun Oct 23, 2005 11:41 am    Post subject: Help needed - start on high logic Reply with quote  Mark this post and the followings unread
Hi! I'm trying to start a sequencer with a logic signal, so it should start out parked and just run from when a logic signal is received... What's the easiest way to do this??? Guess I'm looking for some sort of switch that will turn on at a high logic and stay on even if the logic signal goes on and off... Thanx!
deknow
PostPosted: Sun Oct 23, 2005 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
...i'd say the easiest way is to run the clock into an and gate. the other input to the and gate should be a flipflop. when you trigger the flipflop, the clock will then make it to the sequencer.
deknow
Audio files: 107
PostPosted: Sun Oct 23, 2005 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
How about this?
Seq start stop.pch2
Seq start stop logic
 Filename:  Seq start stop.pch2
 Filesize:  1.18 KB
 Downloaded:  984 Time(s)
deknow
PostPosted: Sun Oct 23, 2005 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
...or this. howard's is probably cheaper.
deknow
seqand.pch2
 Filename:  seqand.pch2
 Filesize:  1.2 KB
 Downloaded:  675 Time(s)
arturmeinild
G2 patch files: 4
PostPosted: Sun Oct 23, 2005 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanx guys... I was looking some more, seems like it was the S&H module I was actually looking for, but I'll check out those patches anyway...
deknow
PostPosted: Sun Oct 23, 2005 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i should have labled my patch better. the top button will allow the sequencer to start, the bottom will reset the flipflop and stop it.
deknow
mps board
