Accent circuit
Page 1 of 1 [6 Posts]
skylab001
PostPosted: Wed Nov 30, 2005 5:12 pm    Post subject: Accent circuit
Subject description: like those used on Roland X0X's
I'm in the middle of creating my own drum & bass synth with sequencer ala the roland X0X series, but with a much different sound, and I'm curious how they made the accent work. I didn't think it would be that difficult but I tried about 5 different basic ideas and none of them gave me the proper results, so now I'm scratching my head.
Does anybody have a diagram or can tell me how to do this. I have only had my G2 for a couple of months so I'm not a pro, but I do understand the basics and am getting better everyday.
jamos
G2 patch files: 35
PostPosted: Wed Nov 30, 2005 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have one, yes.....
.. I don't have time to separate it out into a building block or anything, so in the interest of just getting you going I'll attach a drum thing I'm working on that has it. Try out the knob and button labeled Accent on page A1; look for modules labeled Accent, etc.
AccentedBeats.pch2
Drum machine with accent
 Filename:  AccentedBeats.pch2
 Filesize:  10.55 KB
 Downloaded:  690 Time(s)
cebec
G2 patch files: 31
PostPosted: Wed Nov 30, 2005 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice patch!
jamos
G2 patch files: 35
PostPosted: Wed Nov 30, 2005 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
skylab001
PostPosted: Thu Dec 01, 2005 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch, similiar to a couple of my attempts but works much better. Is this the same as the Roland circuit? For some reason I thought the roland circuit affected the pitch as well as a bit of resonace? Could be totally wrong though
jamos
G2 patch files: 35
PostPosted: Thu Dec 01, 2005 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got me on that. I don't know the details of the Roland accent stuff, I just wanted to create something that worked in a roughly similar manner (that is, capable of setting a global accent on any step, with adjustable amount.) It does that; you could try routing the Accent signal to something other than drum velocities.
Niio2
