Morphing Midi Out Channels.
Page 1 of 1 [5 Posts]
wyleu
G2 patch files: 4
PostPosted: Tue Jan 17, 2006 3:43 am    Post subject: Morphing Midi Out Channels.
Subject description: Trying to allow one knob to control multiple MIDI out channels
I'm mucking around with sequencers and would like to allow two MIDI out channel modules to be Morphed on one knob without resorting to some MIDI assign any ideas or have I missed something again?
I want to be able to play the voiced slot from the keyboard whilst the sequence runs and allow that channel to be selected on a knob that I can build into an overall sequence template.
steppingOut.pch2
Joe Jackson's masterpiece mauled by me.
 Filename:  steppingOut.pch2
 Filesize:  1.54 KB
 Downloaded:  1167 Time(s)
Audio files: 278
PostPosted: Tue Jan 17, 2006 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im not aure I got the question right, but maybe something like :
midi morph
 Filesize:  59.29 KB
 Viewed:  4251 Time(s)
wyleu
G2 patch files: 4
PostPosted: Wed Jan 18, 2006 2:23 am    Post subject: Morphing
Subject description: Channel out.
Sadly no.
I'm trying to arrange things so one knob can alter the Slot A-D settings of both the MIDI out modules. It appears you can't morph this parameter.
Taz says:- 'My Sub My Rules'
G2DREAM
PostPosted: Wed Jan 18, 2006 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you can do this with the variations and cc70 to navigate through variations with all other settings the same and the only thing that changes will be the A-D setting.I don't know if you like this solution or if i am catching exactly what you want to do.
_______________
cyber-evolution
Audio files: 278
PostPosted: Wed Jan 18, 2006 2:10 pm    Post subject: Re: Morphing
Indeed, you'll need some MIDI magic here - which makes the solution slot dependent again (and the 1.4 software has still no solution for that).
