cebec
G2 patch files: 31
Daniel Berthold
Joined: Dec 16, 2005 Posts: 4 Location: Dresden / Germany
cebec
G2 patch files: 31
Posted: Sat Feb 04, 2006 10:25 am Post subject:
| thanks... nice find in the archive, by the way. no, i never tried any of those techniques when i had the NM 1. |
cebec
G2 patch files: 31
Posted: Wed Feb 15, 2006 8:59 pm Post subject:
more (old) experiments in a similar v(a)ein --
i stopped doing these when i started a small analog modular, recently.
i like how these patches sound, though. cliched, perhaps, but 'nice'. thanks to rob, tim, and dave for their ideas.
these patches have knob assignments and variations.
 Download |
| Filename: |
fat wet.pch2 |
6.83 KB |
| Downloaded: |
768 Time(s) |
| attempt at an 'analog' bassline #9 w/ drum |
 Download |
| Filename: |
analogg 9.pch2 |
6.36 KB |
| Downloaded: |
748 Time(s) |
| attempt at an 'analog' bassline #3 |
 Download |
| Filename: |
analogg 3.pch2 |
4.08 KB |
| Downloaded: |
765 Time(s) |
Tim Kleinert
Joined: Mar 12, 2004 Posts: 990 Location: Zürich, Switzerland
Audio files: 6
G2 patch files: 201
Posted: Fri Feb 17, 2006 2:49 am Post subject:
Thanks for the patches, Cebec.
I just want to go on record here saying that I do NOT claim original authorship on the jitter concept. Afaik, it was Robs idea.
There's a (lovely, btw.) vintage lead patch by him in the factory banks called "BackTo72", where this approach is already used -albeit with a Noise/SH circuit, as the random modules weren't yet implemented in the OS back then. There's also some analog frequency response modelling via elliptic filter going on there (a precursor to the tilt filter perhaps). It's a great patch, I learned alot from it and I like to play it too. Thank you, Rob.
However, I want to add that after further reading about analog synths (and especially the quality of their PSUs), I also experimented with modulating osc frequencies with simply a bit of audiorate brown noise, which is much simpler and efficient, and actually doesn't sound much different either. One can also use a fast random LFO, to keep things in the "blue domain" and save DSP. And on the other hand one shouldn't overstate the importance of osc jitter for the "analog sound". I set the G2 side to side to the Prophet5 (Rev3) to make some comparisons, and found that the CEM oscs of the P5 are actually rock-stable. They drift over a long term, but they don't jitter at all. Actually, I managed to recreate P5 sounds on the G2 spot on, without any hassle. I mean, you couldn't hear a difference when closing your eyes. I even made blindfold experiments with friends. Everyone was fooled. (The only thing that gives the G2 away in a big way is using sync and FM in tandem. Aliasing. ) _________________
cebec
G2 patch files: 31
Posted: Fri Feb 17, 2006 9:17 am Post subject:
| tim wrote: | Thanks for the patches, Cebec.  |
you're welcome!
| tim wrote: | | there's a (lovely, btw.) vintage lead patch by him in the factory banks called "BackTo72" ... |
yeah, this is one of my favorite patches from the factory set, too. so smooth and creamy.
| tim wrote: | | (The only thing that gives the G2 away in a big way is using sync and FM in tandem. Aliasing. Rolling Eyes) |
In my first analog acquisition since I had an Odyssey 7 years ago, I patched up FM, crossmodulation, and sync, immediately. The difference is noticeable in a way you once described it, tim: it seems almost speechlike, at the very least. And, to tie into another thread, do you think an internal SR in the MHz range could be sufficient to approach that character? |
Tim Kleinert
Audio files: 6
G2 patch files: 201
Posted: Fri Feb 17, 2006 1:23 pm Post subject:
| cebec wrote: |
Oh, most definetely. Because it isn't just a question of character, but of accuracy. The current sampling rates just cannot handle the sidebands yet.
Sine-based FM works well on digital, because sinewaves have no sidebands at all. Using a sawtooth wave is a completely different matter however.
Even when doing AM with two anti-aliased sawtooths, they will generate sidebands beyond the sample rate. The waveforms will be bandlimited to half the sample rate, but the sum frequencies will go above that. So actually it would be good to have a "sample rate headroom", just like we have an amplitude headroom. Right now, on a 96 kHz system, it can be beneficial to bandlimit primary audio sources (oscs etc.) to 24khZ, leaving more headroom for sidebands and reducing the risk of foldbacks. _________________
eposk
Joined: Apr 29, 2005 Posts: 155 Location: Portland, OR
Posted: Fri Feb 17, 2006 7:40 pm Post subject:
| rad patch! Its so very fat. |
