 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
DIY Polysynth
Page 1 of 1 [2 Posts]
Axiom
G2 patch files: 28
PostPosted: Sun Mar 05, 2006 7:12 am    Post subject: DIY Polysynth
Subject description: some DIY Oscillators and filter
Hi all,
in this days i've played around with some diy way to generate waveforms. I've figured out some nice tricks using a saw core oscillator and, then, doing waveshaping with logic modules and mixers. Drift is simulated using a clocked random module running at oscillator frequency. A note about PWM: it works opposite to "standard" pwm... to reduce the pulse size you have to turn the knob counterclockwise.
The filter section is a simple 3 pole filter done following the evergreen Rob's workshop. Inspired by the VCFS thread, i've tried to use a X-Mux to switch the slope.. nothing really interesting, but is nice Wink
This synth isn't completed. It lacks lots of modulation paths that I will add later.
The patch have only 3 variation and, then, all Var1 copies.
Enjoy
AxPolySynth2.pch2
Axiom's DIY Polysynth
 Filename:  AxPolySynth2.pch2
 Filesize:  6.83 KB
 Downloaded:  844 Time(s)
axdiypoly.mp3
Sample file for DIY Polysynth
 Filename:  axdiypoly.mp3
 Filesize:  724.99 KB
 Downloaded:  480 Time(s)
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
Axiom
G2 patch files: 28
PostPosted: Tue Mar 07, 2006 2:50 pm    Post subject: Axiom's DIY Polysynth v2 Reply with quote  Mark this post and the followings unread
Here's an updated version of DIY Polysynth.
New features:
- Oscillator 2 now uses another waveform set (check Building Block thread about it).
- Added Osc1>2 sync
- Added Velocity to filter env.
- Some little bug fixes.
Enjoy Smile
Luca
AxPolySynth2_1.pch2
 Filename:  AxPolySynth2_1.pch2
 Filesize:  7.24 KB
 Downloaded:  787 Time(s)
Niio1
