 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
realtime sequencers... as work in progress thread...
Page 1 of 1 [5 Posts]
3phase
G2 patch files: 138
PostPosted: Fri Mar 10, 2006 9:00 pm    Post subject: realtime sequencers... as work in progress thread...
Subject description: as work in progress thread...
I posted quite a few g2 patches on the list..i start placing them here aswell..
some maybe on my webpage at one point...
I think this thing explaines itself....ad quite a bit fun with it..hopes it still works...was my first g2 patch ....
RealQnz Deal.prf2
 Filename:  RealQnz Deal.prf2
 Filesize:  19.3 KB
 Downloaded:  808 Time(s)
3phase
G2 patch files: 138
PostPosted: Fri Mar 10, 2006 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
shit..wrong patch...
this is a complicated note sequencer... but anyway..cant do a manual wright now...
it records when the pitchwheel is up..you can copy and overdub patterns..
gate time recording...
but you have to change pitches..so no stakato notes on ane pitch..
and note that some of the internal sequence bits might be copywrighted material...when you get this tool working you will have dozents of own sequences in minutes...
I used this patch with succes live...
3phase
G2 patch files: 138
PostPosted: Fri Mar 10, 2006 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok here the real patch...aktually i like the idea to have different sequencer konzepts in one thread Wink Because i actually like to combine them somehow... controled random and realtime recording..thats the patch i need.
so if anybody improoves this 2 sequencing attempts please post variations here...
i rename the topic in realtime sequencers...
LFo Quencer Deal.pch2
 Filename:  LFo Quencer Deal.pch2
 Filesize:  4.67 KB
 Downloaded:  738 Time(s)
3phase
G2 patch files: 138
PostPosted: Mon Mar 20, 2006 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
And one more on the search for the ideal stage companion..This time its based on the Multitrack patch of Palle Dahlstedt..
opposite to Palles patch there is a polyphonic mode additional to the monophon 4 track tactics Palle have chosen.
I would love to combine this with the store ability of the realquencer at a later point...
maybe by transferring the data from the sample delay sequencers in the VA to the fx where note sequencers do the recording for each voice and transmit the result to a soundengine in another slot.
Just the question how to do that...
<edit..and update to plaaequenz 0.6 with improoved erase behavior.
First the timing problem needs to be solved...
PalleQuenz 0.6.pch2
 Filename:  PalleQuenz 0.6.pch2
 Filesize:  5.96 KB
 Downloaded:  690 Time(s)
3phase
G2 patch files: 138
PostPosted: Fri Mar 24, 2006 6:47 am    Post subject: 4 voice polyphonic realtime sequencer, strorable
Subject description: a big and good one
Ok..seems that here is not so much to discuss about sequencers...
I anyway hope that clavia will bring up some new modules earlier or later...
Further steps with these sequencer will be published on my webpage.
www.3phase.de
PolyQuenzer A is a mixed konzept that combines the realquencer with the pallequencer.
You can record long sections with the VA that still has place to hold its own sound, with two independend loop lines that can copy into each other. transfer 2 bars to the fx area where it will be stored. overwrite single voices in the fx area or send the stored content of the fx area back to the VA loop delay lines... The fx area is also prepared to send the sequnce to another slot (slot c)
The sequencer is build to be in slot B...look for the red modules when you want to play it inanother slot...
We have quite a few functionalitys here that pushing the borders of the actual G2 system a bit...therefore the patch is big...
But some of you might find it usefull...
PolyQuenzer A.pch2
 Filename:  PolyQuenzer A.pch2
 Filesize:  11.18 KB
 Downloaded:  789 Time(s)
