 Forum index » electro-music.com » Help
How to add your events to the calendar
Audio files: 143
PostPosted: Mon Mar 20, 2006 7:42 am    Post subject:  How to add your events to the calendar
Subject description: Important reading before posting to this forum.
Events announced on this News -> Concerts and Festivals forum can be added to the electro-music.com calendar. A mini calendar module always appears on the upper right column of the front page and there is a link to the expanded calendar page from every page on the forum.
To take full advantage of posting an announcement of your event on electro-music.com you should certainly add your event to the calendar. Activating the calender is very easy. This message explains how to do it.
The calendar feature is only available on the first post to a topic, so if you have multiple events to post, make a new topic for each one. When you are editing your post, notice that there is a button that looks like a little calendar - click on it.
A new window will open where you can enter the date of the event. Just select the month and year and click on the date. If this is a single date event, then you are finished.
If your event has a start date and end date, or if it is a repeating event (like every Saturday for 4 weeks), then check the Advanced box and additional data entry widgets will appear.
In the following window we enter an event that runs through April 28, 2006 and repeats every week.
When click on the submit post will be added to the forum and the event will appear in the calendar. If you made a mistake or need to later change the date for some reason, just click on the edit icon on the post with the calendar entry as shown below.
If you have any questions or difficulties, please post them as replies to this topic.
Thanks...
