Brickwall sampling filter creating manyLoFi aliasing effects
Page 1 of 1 [3 Posts]
Rob
G2 patch files: 109
PostPosted: Mon May 15, 2006 9:05 am    Post subject: Brickwall sampling filter creating manyLoFi aliasing effects Reply with quote  Mark this post and the followings unread
The idea for this one is cooked up by Kassen and me. The idea is to use two S&H modules and use alternate clocking combined with crossfading between the two. The alternating clocks are derived from the crossfader control waveform, one S&H clocks on the positive peak maximum, while the other clocks on the negative peak minimum.
As crossfader waveform either a triangle or a sinewave can be used. Some waveshapes from the Shape oscillators are also quite interesting.
By definition no frequency higher as the clockfrequency can be passed, but this perfection is neatly compensated by an interesting sonic scala of aliasing artifacts beyond the 'cutoff' frequency.
Kassen discovered how to make this circuit resonate. This resonance is interesting as it actually superimposes the crossfader control waveform on the output signal.
Right now two main artifacts are added to the filtered signal, aliasing that depends on the frequency ratio of the input signal and the clocking signal, plus aliasing caused by the synchronization of the S&H's to the system sample rate. The first type of aliasing can be considered to be wanted, to create all sorts of effects that are easily associated with a LoFi digital sonic character. There is lot of control on how this aliasing sounds.
The jitter caused by the interaction between the system sample rate and the clocking sample rate is less wanted, as it sort of causes sharp transients in the input waveform to be jittered. I suppose a samplerate of 4MHz should solve that sufficiently, but that needs to wait a couple of years. Wink
FltBrick.pch2
A curiously sounding resonant filter with lot's of LoFi aliasing sound control. Basically it is close to the ideal digitizer module.
 Filename:  FltBrick.pch2
 Filesize:  3.08 KB
 Downloaded:  799 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Mon May 15, 2006 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fun patch to experiment with !
Fozzie
G2 patch files: 49
PostPosted: Mon May 15, 2006 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
And good to see you active on the forum again, as well. It appears you're back from a sort of break too much coffee
Niio2
