monobass
G2 patch files: 12
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Fri Jun 02, 2006 8:19 pm Post subject:
are you hearing comb filtering effects perhaps...? just taking a guess...but if so, then that would be pretty hard to avoid _________________ Spiral Recordings |
monobass
G2 patch files: 12
Posted: Sat Jun 03, 2006 2:32 am Post subject:
paul e. wrote: | are you hearing comb filtering effects perhaps...? just taking a guess...but if so, then that would be pretty hard to avoid |
If you open up the patch and then simply turn the mid volume knob all the way down and up you can hear the effect. Especially the way it seems to get quietest at about 10% on the knob and then actually louder at zero. I guess it's something to do with the crossover of the EQ's.
It's not a terrible thing, I'm just interested in why it happens and I'm sure there are many ways of achieving the effect I'm after. _________________ Steve |
Posted: Sat Jun 03, 2006 4:41 pm Post subject:
Probably there are many ways but problems in this field tend to involve very hard math. Just this afternoon I saw some equations involving complex numbers (those aren't all that bad, at least I understand the concept) and mathematical signs I never saw before (that always means trouble).
I'm nowhere near a G2 editor right now but 10% sounds like a lot, that probably means something is wrong. This effect in general is simply something you may have to live with or switch to FIR filtes (which would likely be on a computer). I recomend doing what most eq desigener seem to do; pick settings that sound reasonable for most realistic applications. _________________ Kassen |
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Sat Jun 03, 2006 5:30 pm Post subject:
interesting stuff.
But why is this a performance out of curiousity and not just a patch? |
monobass
G2 patch files: 12
Posted: Sat Jun 03, 2006 5:34 pm Post subject:
Jason wrote: | interesting stuff.
I always start every patch as a performance, as I find everything generally ends up as one anyway!  _________________ Steve |
Jason
Posted: Sat Jun 03, 2006 5:57 pm Post subject:
Right on! Just wondering, I havent really made perfs. |
Tim Kleinert
G2 patch files: 236
Posted: Sun Jun 04, 2006 3:22 am Post subject:
Isn't it this what you are looking for? |
monobass
G2 patch files: 12
Posted: Sun Jun 04, 2006 12:48 pm Post subject:
tim wrote: | Isn't it this what you are looking for? |
Aha, Thanks!
Phase Linear is what i'm after, unfortuantely when I try and download Rob's patch it just hangs though. _________________ Steve |
Posted: Sun Jun 04, 2006 4:05 pm Post subject:
I just downloaded & opened, ok for me. |
monobass
G2 patch files: 12
Posted: Sun Jun 04, 2006 4:28 pm Post subject:
jksuperstar wrote: | I just downloaded & opened, ok for me. |
Ah yeah working fine now, electro-music as a whole was really chugging but seems fine now.
Actually I'm quite impressed with myself that my solution was very close to Rob's I had just used a hi-pass for the hi-end rather than subtracting the lo-pass, which was causing the slight crossover artifacts. _________________ Steve |
