  bingsatellites Mostly Ambient
Individual Sequencer Outputs
Page 1 of 1 [3 Posts]
Axiom
G2 patch files: 28
PostPosted: Thu Jul 13, 2006 2:16 pm    Post subject: Individual Sequencer Outputs
Subject description: Dirty 'n' cheap solution
I very feel the missing of a sequencer with indipendent logic outputs. Today i've found this unelegant but working solution using two 8bit counters in series. Dunno if anyone already did it so.. here's the patch Smile
Luca
IndividualSeqOutputs.pch2
 Filename:  IndividualSeqOutputs.pch2
 Filesize:  956 Bytes
 Downloaded:  681 Time(s)
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
Audio files: 107
PostPosted: Fri Jul 14, 2006 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a good idea. Sometimes it's good to have individual outputs from a sequencer. Here's another way to do it where the outputs will follow an arbitrary signal - in this case a LFO. Change the waveform and you will get different patterns.
indiv-out-2.pch2
Building block to have individual logic outs from a 16 stage sequence that follows and analog input signal. Note that there are special outputs for bits 8 and 9.
 Filename:  indiv-out-2.pch2
 Filesize:  1.12 KB
 Downloaded:  1013 Time(s)
Axiom
G2 patch files: 28
PostPosted: Fri Jul 14, 2006 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting way Smile
Now I have to apply my building block for a Performance Smile Stay tuned.
Luca
