 Forum index » Clavia Nord Modular » G2 Performances - Noodles
Work Delay
Page 1 of 1 [14 Posts]
PostPosted: Fri Nov 17, 2006 5:25 am    Post subject: Work Delay
Subject description: G2 Demo noodling at work
I propose a new category for NMG2 patches: noodles made in the demo while doing boring stuff at work! Very Happy
Here's one - it's one of my usual delay abuse experiments. The amount of different kinds of things you can do the modulated delay module... joker
Mind your ears if using headphones!
/Stefan
sbt_work_delay.pch2
Work Delay
 Filename:  sbt_work_delay.pch2
 Filesize:  3.07 KB
 Downloaded:  2279 Time(s)
PostPosted: Fri Nov 17, 2006 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW, if you load this into a proper G2, you can try to hook up an input module where the oscillator envelopes go in. Haven't tried it myself yet...
/Stefan
mother misty
G2 patch files: 130
PostPosted: Fri Nov 17, 2006 6:32 am    Post subject: Re: Work Delay
/Stefan
Great idea! Smile
Pitty i can only upload stuff, everytime i try do download something i see a text file (mac/safari)
anyone knows how to solve this?
(i'm not really a mac guy Smile ) and renaming it to .pch2 doesn't seem to work
Audio files: 278
PostPosted: Fri Nov 17, 2006 2:58 pm    Post subject: Re: Work Delay
Oh man I wish I would ever get that bored at work. It would help relief stress for sure.
Is a nice patch, did the input modification and dropped it in between some of my patcxhes, making up a larger noodle.
PostPosted: Thu Nov 23, 2006 3:01 am    Post subject: Re: Work Delay
[quote="Blue Hell"]
Yes, I suppose I shouldn't complain, although having a busy job doesn't have to be a bad thing, I think (although I don't presume to know anything about your situation).
Thanks for trying it out!
/Stefan
windchill
PostPosted: Thu Nov 23, 2006 4:57 am    Post subject: Mother Misty's mac problem Reply with quote  Mark this post and the followings unread
Here's what I do to download with Safari. I click on the download link and let the text file appear, I then select "save as" from the file menu, a dialog box will come up asking whether you want to append .txt to the file - select 'NO' and the file will download.
You will also need to tell the Mac that you want the G2 demo to open these files. Select the file then select the file menu and the "get info" option - the rest should be obvious.
(Macs can be amazingly stupid sometimes ... but I won't go any further lest I start a flame war!)
Audio files: 278
PostPosted: Thu Nov 23, 2006 2:11 pm    Post subject: Re: Work Delay
I'm still trying it out Exclamation
It's ok again to be busy on the job. Was overstressed a bit some months ago. but then noticed I had several weeks left of holidays to take up and decided to work just four days a week for some months - that seems to have done the trick.
cappy2112
PostPosted: Fri Dec 08, 2006 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Stefan
What do you mean by a proper G2?
W.T.
G2 patch files: 11
PostPosted: Sat Dec 09, 2006 10:16 am    Post subject: Re: Work Delay
mother misty wrote:
/Stefan
Firefox perhaps? works fine on my mac and downloading a g2 patch.
PostPosted: Mon Dec 11, 2006 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
cappy2112 wrote:
/Stefan
I mean an actual G2, G2 engine or G2x. The input module isn't supported in the demo, so it isn't implemented in this noodle, which was constructed without access to the NMG2 hardware.
/Stefan
cappy2112
PostPosted: Mon Dec 11, 2006 8:10 am    Post subject: Re: Work Delay
/Stefan
Hey- that's a good idea. The demo would be great for travelling. I wouldn't have to carry the engine with me, and be concerned if ti would get confiscated by airport security.
How many of the modules/voices are supported by the demo?
PostPosted: Mon Dec 11, 2006 9:03 am    Post subject: Re: Work Delay
/Stefan
From the text at http://www.clavia.se/products/nordmodular/demo.htm:
    *Polyphony is limited to one voice while the hardware has a maximum of 32 voices per sound.
    *The demo can only play one sound at the time while the hardware is 4 part multitimbral.
    *A couple of modules are disabled.
    *The demo does not support audio in and MIDI out.
The most notable unsupported module is reverb, besides the I/O specified above.
/Stefan
Audio files: 278
PostPosted: Mon Dec 11, 2006 9:20 am    Post subject: Re: Work Delay
Reverb works in the 1.4 emulator, in earlier versions it didn't.
PostPosted: Mon Dec 11, 2006 2:07 pm    Post subject: Re: Work Delay
Man, you're right! Shocked Very Happy
Thanks for correcting.
/Stefan
