Modular Synthesizer Pictures
Page 4 of 26 [629 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 24, 25, 26 Next
synth_ollie
PostPosted: Mon Sep 25, 2006 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
oooops, I deleted some audiofiles from my webspace, the pic must have gone too... I´ll se if I can fix it.....
G2 patch files: 626
PostPosted: Mon Sep 25, 2006 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Synth_ollie, nice system.
When I see big 100M systems I am reminded of Rolands "Big clearance" where they internationally dumped all the 100M modules for very low prices.
I think Mr Zimmer got his for about UK10 each.
In NZ, all the warehouse stock went to someone who latter lost the lot in a fire.
Were you one of the lucky ones?
synth_ollie
PostPosted: Mon Sep 25, 2006 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
hehe, maybe not that lucky....
I had a few cabs early 1990´s and then got a couple more, then a few years ago I was lucky to get 6 more cabs from a guy in finland at a very good price, then I had 12 cabinets
however, that system vas sort of "too big to handle" so I sold off 3 cabs and today I have 9, wich is the least you gotta have if youre gonna have some rollie 100m fun Smile
OLLIE
mono-poly
PostPosted: Thu Nov 02, 2006 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Serge panels
http://www.mijnalbum.nl/Album=PEUXPL8D
My Wiard (old pic, it's bigger now)
loopcycle
PostPosted: Mon Nov 06, 2006 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
cant have too many modular synth pics.
here's an older pic of mine:
Per
PostPosted: Sat Nov 11, 2006 4:08 am    Post subject: A Doepfer tower Reply with quote  Mark this post and the followings unread
This is my modular, just over 120 modules, most of it is Doepfer. It has reached it´s peak in hight, as the two racks with Metasonix modules can´t be put on the top.
There are still some modules on the way in, one Cyndustries Zerooscillator (still waiting for delivery) and one Dopefer Dynamic VCO (not yet in production).
My plan is to build a wooden casing for it that is three 19" racks wide and 7 x 3HU racks high. But it still has to be done.
I theory, it is capable of 14 independent voices with VCO, VCF and so on. But in practical use, I seldom exceed seven or eight voices, as they tend to fill the whole sound spectrum.
I started with three 6HU racks three years ago, and thought by than that it would be enough for the rest of my life.
But I was wrong.
Per Wikstrom
Still under construction but at least a +120 module system
 Filesize:  2.02 MB
 Viewed:  18322 Time(s)
Audio files: 228
PostPosted: Sat Nov 11, 2006 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice set up, Per. Very Happy
bigtex
PostPosted: Sat Nov 11, 2006 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess earthquakes aren't an issue in the great white north... Laughing
In the San Francisco area, I could never dream of stacking something up so high without mounting it to rack rails. The thought of it all coming crashing down is too scary :
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Nov 11, 2006 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Per,
you must be a very tall guy to be able to reach the top of that stack of modules Cool
Per
PostPosted: Sun Nov 19, 2006 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I am not so tall at all, so it has reached it´s limit in size...
There are actually some problems that occurs when the system gets this big. Even the l20 cm/50 inch cables are too short to cover the full hight. Of course DIY cables is possible, but solder 50 cables is nothing I look forward to do.
With increasing size, the layout gets increasingly important. The modules that are used together must be mounted close to each other to avoid a total cable mayhem.
I have redesigned the system many times to get it right. Now there are one area for clock and gate processing, one for CV and CV processing and separate VCO, VCF and VCA areas. Audio processing is still spread out, and I have no good solution for that yet.
On the other hand, part of the fun is to rebuild the machine. And strangely, I have noticed that when I arrange the modules in new ways, it change my wat of using them.
Modulars is an intuitive business.
Per
synth_ollie
PostPosted: Mon Nov 20, 2006 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
hey per, great soundclip !
mono-poly
PostPosted: Mon Nov 20, 2006 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok the studio rebuilding:
 Filesize:  452.1 KB
 Viewed:  18238 Time(s)
 Filesize:  430.61 KB
 Viewed:  18166 Time(s)
 Filesize:  407.47 KB
 Viewed:  18170 Time(s)
synth_ollie
PostPosted: Mon Nov 20, 2006 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
"premium bananas" Smile
mono-poly
PostPosted: Mon Nov 20, 2006 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Yeah i am waiting for some sixpacks to arive.
Then i can make a nicer and bigger case
PostPosted: Thu Nov 23, 2006 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
so i join the parade...
here's a pic of the tiny modular i built last year. the 2nd cabinet is under construction and will show more custom modules from selfmade PCBs...
cheers,drunken
PostPosted: Fri Nov 24, 2006 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice 70's style knobs, fonik!
ACHTUNG!
mono-poly
PostPosted: Fri Nov 24, 2006 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah nice pic.
EMU Modular style knobs!
REwire
PostPosted: Wed Dec 06, 2006 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Eurorack setup with Cwejman, Blacet, Cynthia, Doepfer, ASol, Asys, Buchla, Steiner Parker and Plan-B:
And my patchable synths all wired together:
Dan
http://www.REwireMusic.com
Buy REwire - "Bit By Bit" CD at http://cdbaby.com/cd/rewire
Album Promo Video:HERE
PostPosted: Wed Dec 06, 2006 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
REwire's Music and Synth Collection
Hey Dan,
the track that you did with the VCS3 is awesome!! Really fun Very Happy
It really is 'the Dr Who' synth don't you reckon??
welcome to electro-music.com btw Very Happy
ACHTUNG!
Audio files: 228
PostPosted: Thu Dec 07, 2006 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, great stuff.
Rob
G2 patch files: 109
PostPosted: Sat Dec 09, 2006 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Small, but pretty freaky. Actually inspired by the old oakwood box it is in.
And how it sounds:
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox01.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox02.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox03.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox04.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox05.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox06.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox07.mp3
http://www.xs4all.nl/~rhordijk/Junk/BlippoBox08.mp3
PostPosted: Sat Dec 09, 2006 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Rob,
where did this mean beast appear from ??
Wanna post the schematics in the DIY section?? Wink
PS, I like the fact that you made it quite clear that you now have a VCS3!! Very Happy
Tom
ACHTUNG!
Rob
G2 patch files: 109
PostPosted: Sat Dec 09, 2006 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Rob,
The darker abyss of my soul. happy smoker
Yeah, I can do that, though I need to organize some scanner first to scan some notebook pages.
Tom
Hmm, I'm not much into that gearlist thingy, but yeah, there's the usual stuff and a couple of unusual toys. Wink
/Rob
PostPosted: Sun Dec 10, 2006 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic and thanks Smile It will make a lot of E-M DIY'ers very happy Smile
(especially as it's a Hordijk design Very Happy Cool )
ACHTUNG!
Carbon111
PostPosted: Wed Dec 13, 2006 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my modest modular:
More info here:
http://www.carbon111.com/serge.html
http://www.carbon111.com/animal.html
