 Forum index » Clavia Nord Modular » G2 Patches - Completed » External Control
Machinedrum Mutator
Page 1 of 1 [15 Posts]
mother misty
G2 patch files: 130
PostPosted: Wed May 03, 2006 5:06 am    Post subject: Machinedrum Mutator Reply with quote  Mark this post and the followings unread
A G2 Midi Control Automate patch made for the Elektron Machinedrum.
With this patch you can use the patch mutator on your MD,
a great and easy way to make mutations of existing Machinedrum kits!
(this is so much fun! Smile )
(your MD has to be set at midi channel 10-11-12&13 to make this work
otherwise you have to change the 240 cc's in this patch)
enjoy!
MD_MUTATOR.PCH2
Elektron Machinedrum Midi Control Automate patch
 Filename:  MD_MUTATOR.PCH2
 Filesize:  14.55 KB
 Downloaded:  1738 Time(s)
Audio files: 156
PostPosted: Wed May 03, 2006 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
For those of us that don't have a MD, can you post an mp3 or two?
jksuperstar
G2 patch files: 18
PostPosted: Wed May 03, 2006 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Pardon my bloody language, but what a great fucking idea! (using the mutator to control some other gear).
I'm already thinking of a port for some of my other gear, like an Alesis DMPro, or maybe my CZ-1000. I wonder how much havoc this would play with assignment to an Ableton Live set? Smile Smile
mother misty
G2 patch files: 130
PostPosted: Thu May 04, 2006 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure I can, here's an MP3.
In this example slot A contains the MD mutator and slot B the MD sequencer.
The first 15 seconds is the original kit with a pattern generated by the mutator (started from an empty pattern)
All the stuff after 15 seconds are bits & pieces of mutations from the original kit and pattern.
enjoy
G2VSMD.MP3
Elektron MachineDrum Patch Mutator example
 Filename:  G2VSMD.MP3
 Filesize:  2.36 MB
 Downloaded:  1415 Time(s)
Audio files: 156
PostPosted: Fri May 05, 2006 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
eposk
PostPosted: Fri May 05, 2006 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
hell yes. mutations are my best friend.
mother misty
G2 patch files: 130
PostPosted: Sun May 07, 2006 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi all,
some people asked me if I could post a "live" mutation, so here's one.
enjoy!
G2VSMD2.MP3
MachineDrum live mutations
 Filename:  G2VSMD2.MP3
 Filesize:  1.45 MB
 Downloaded:  1262 Time(s)
Ivity
G2 patch files: 57
PostPosted: Tue May 09, 2006 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Very impressive MP3 Very Happy
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
W.T.
G2 patch files: 11
PostPosted: Wed May 24, 2006 2:29 pm    Post subject:   Reply with quote  Mark this post and the followings unread
nice, although it is very random it gave my md some good starting points to make kits. thanks for the 'arbeit' Smile
modularbrain
PostPosted: Sat Jul 15, 2006 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
wow!
any chance of having a similar patch for the old NMK?
MB.
W.T.
G2 patch files: 11
PostPosted: Sun Jul 16, 2006 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
MB.
Shocked check the g1 and g2 specs end find out why not, Very Happy
gotascii
PostPosted: Thu Mar 08, 2007 1:49 pm    Post subject: zip sound in the live mutation.. Reply with quote  Mark this post and the followings unread
I know this is a super old thread..I was digging Smile I'm wondering where that zippy/fast bouncing ball sound is coming from that is present through most of the live morph mp3...Is that a feature of the machinedrum or the g2? It sounds like something getting retriggered really fast with some kinda of random amplitude/pitch envelope but I can't really figure it out. I've been trying to create something like that for ages in max...
mother misty
G2 patch files: 130
PostPosted: Mon Mar 12, 2007 7:59 am    Post subject: Re: zip sound in the live mutation.. Reply with quote  Mark this post and the followings unread
Hi gotasci!
I guess you're talking about the first mp3?
These are samples with a modulated retrigger time.
It's easy to do that the MD, but a G2 should be able to do something similar as well.
Ivity
G2 patch files: 57
PostPosted: Mon Jul 23, 2007 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
This is slightly modified version of Mother Misty's MD mutator.
My patch controls only 8 first tracks, but it works with standard MD channel settings (1-4) and also includes most important (IMHO of course) effects and routing parameters.
BTW: If you want to control other 8 tracks - just copy this patch to another slot and change MIDI-chanels to 3 in VA and to 4 in FX Very Happy
MDctrl_1-4.pch2
 Filename:  MDctrl_1-4.pch2
 Filesize:  4.55 KB
 Downloaded:  1291 Time(s)
Igor
Unfed
G2 patch files: 11
PostPosted: Mon Jan 19, 2009 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
recently got a MD/UWmkII and just loaded up this patch. nice!
for some reason though, it has no effect on Tracks 2,3,4,6,7, and 8. ??? i can manually move the knobs in the Editor and the changes are reflected on the MD, but when using the Mutator it does nothing to the parameters. the knobs in the Editor change, but no response from the MD. all other tracks work as they should. it's set to MIDI channels 10-13, just as it should be. any ideas?
Misty - your email (as listed in the patch) seems to be defunct? hopefully you'll see this...
