question about the tm-1
kirby
PostPosted: Sun May 07, 2006 8:13 pm    Post subject: question about the tm-1 Reply with quote  Mark this post and the followings unread
Hello all,
Maybe some of you can help me. I recently borrowed and may purchase a Metasonix TM-1. I cant seem to tell if it's working properly. I've been plugging an array of equipment from a guitar, a dat machine and a pulse generator etc,etc.. in the audio input as well as various tone generators into the ringmod carrier section, the vca cv and the beam cv and the only time i get any fluctuation in sound is when it's in the vca cv. The owner, a trusted friend was present when i did all this and he basically said "yep, doesn't do much, thats why im selling it". He doesn't have the users manual so i dont know if im doing something wrong. Also the tube isn't quite as bright as the Agonizer i recently saw someone demonstrating. Perhaps the tube is run down. It's a very dim red light.
Correct me if im wrong but isn't the input for the ring mod carrier supposed to alter the sound? I mean, if i plug a low frequency sine wave in the input and a plug a higher frequency sw in the ring mod carrier, shouldn't i be hearing the sum and difference? There is no change to the signal at all. I've spent an hour trying everything and it just doesn't seem to do anything(except for when i plug something into the vca cv input).
Just wondering if other Tm-1 owners have experienced something similiar.
any info would be appreciated.
thanks
kirby,
PS: Its an older version, the gold colored one. Hope its not a goldbrick...hehe.
Audio files: 143
PostPosted: Sun May 07, 2006 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, Kirby. welcome
I don't have a TM1, but you are right to expect the sound of a ring modulator to change significantly when you change the carrier input.
Hopefully, someone with a TM1 will chime in, or maybe we'll hear for Mr. Metasonix himself...
metasonix
PostPosted: Sun May 14, 2006 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry to hear this TM1 has a problem. Probably the beam-modulator tube is bad. You need to drive the ringmod input with a REALLY strong signal, so keep that in mind.
Contact me directly, I can repair the module or at least send you a new set of tubes. Sometimes the tubes get damaged in shipment, and the new owner isn't aware it isn't working because they aren't familiar with the device.
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger MSN Messenger
