Front panels
Page 1 of 1 [14 Posts]
Yorky
PostPosted: Wed Nov 22, 2006 12:19 am    Post subject: Front panels Reply with quote  Mark this post and the followings unread
Does anyone have any tips please on how to make 'pro' looking front panels.
I'm making 10-step sequencers in a 1U rack and a decent front panel is important as I intend to sell them.
These are CV/gate out and 1 to 10 steps, voltages on pots.
Thanks, John
Lots of new albums at Ambientlive
slave to this
G2 patch files: 7
PostPosted: Wed Nov 22, 2006 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd start here at the synth diy (if you haven't already gone this route). just by typing front panel, i receieved a bunch of hits.
http://search.retrosynth.com/synth-diy/index.html
these other two are more diyers that created some how to's that could be of use that i have found over time.
http://www.mikmo.dk/synthpanels.html
http://www.hotrodmotm.com/drill_howto.htm
hope this helps at least some.
PostPosted: Wed Nov 22, 2006 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the new artwork for my dual saphire flanger. The actual image is three times this resolution, and when I print it I'll turn off the "controls" layer and replace it with cross hairs for drilling. It's all done in photoshop. I'm going to print it onto Lazertran and then bake it onto the panel, which I'll paint yellow first. (guess where I got that idea from!)
I like doing it this way 'cos I can turn layers on and off, add effects, change fonts etc. and get a really good idea of what it will look like.
Any questions, you know where to find me. Smile
 Filesize:  59.37 KB
 Viewed:  5193 Time(s)
zonkout
PostPosted: Wed Nov 22, 2006 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I plan to use this method:
http://www.sdiy.org/xyzzy/panels/
http://electro-music.com/forum/topic-13993.html
Yorky
PostPosted: Wed Nov 22, 2006 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys, I'm going to try Lazertran
Any suggestions on layout s/ware ?
PostPosted: Wed Nov 22, 2006 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are dedicated panel design programs, but I like Photoshop. Mostly because I've just gotten to the point where I know how to do what I want to do and I don't have time to learn another program. I also use Photoshop for image manipulation in general, and website design, so it makes sense for me to use it alot. Plus, Adobe just bought Macromedia, so I think we're all going to be using Photoshop (or something like it crossed with Flash) for a while yet.
Yorky
PostPosted: Wed Nov 22, 2006 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, I use Paint Shop Pro.
I could use Visio as well, it has the symbols.
But I se PSP instead, because I'm happy with it for all my artwork, not just panels.
Mikmo
PostPosted: Thu Nov 23, 2006 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check my site (mentioned above) www.mikmo.dk
I use a program called front designer (not to be confused with front panel designer)
It's really good
demo downloadable here www.abacom-online.de
Stay Cool
Mikael
http://www.mikmo.dk
bugbrand
PostPosted: Fri Nov 24, 2006 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
In the past I've used Front Panel Designer and then printed it to file (maybe by printing it as a pdf document - you can get a free demo software called Virtual PDF). This PDF can then be taken into Photoshop (or other editing software) for the final tweaks and whatnot.
Its a shame that the www.cncpanels.co.uk guy has had to stop doing his service 'cos it looked very good and well priced.
http://www.bugbrand.co.uk
Yorky
PostPosted: Mon Nov 27, 2006 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got Front panel designer but it's a bit much, all I want to do is lay out some pot dials and switch legends.
I could do that in Word or Paint Shop Pro or Visio.
All I need is the 'dials' images etc ... any ideas please ?
jksuperstar
G2 patch files: 18
PostPosted: Mon Nov 27, 2006 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Do the dials really need to be fully labeled with a ring & numbers to scale? or will simple markers or numbers suffice (such as just labeling full swing and minimum)? Maybe add an extra marker for the midpoint, or wherever zero db is? That might end up with a cleaner looking panel, rather than printing & grahpics all over the place, which also probably has more chance of failure (during baking, transfer, etc). The kno
I think a lot of it depends on the size of knobs you use also (big old fashion style, or small ones).
fluxmonkey
PostPosted: Mon Nov 27, 2006 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
nifty tool for creating dials: http://stiftsbogtrykkeriet.dk/~mcs/Scale.html. use it to create an HPGL image, which costs a LOT less than laying out multiple lines in frontPanelDesigner.
there's also a ModularSynthPanel yahoo group--http://launch.groups.yahoo.com/group/ModularSynthPanels/.... they've got lots of FPD files in the file section which make good starting points.
bbob
Yorky
PostPosted: Mon Nov 27, 2006 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes it's for a sequencer, so the dials do need a full set of numbers
bbob - many many thanks for that scale-o-matic link, it's just what I need
PostPosted: Tue Nov 28, 2006 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
For dials in Photoshop I just draw a line, and then copy it onto itself. Then I go into the rotate tool and set the centre of rotation in the middle of the line. Then rotate it in 30deg increments leaving a copy as you go. Then add a circular mask and wipe out the middle and the outside.
I know it sounds daunting, but you only need to do it once. You'll be surprised how professional it will look with only a minimum of practice.
