 Forum index » Instruments and Equipment » Cubase
exporting audio in cubase
larns
PostPosted: Mon Jul 10, 2006 2:26 pm    Post subject: exporting audio in cubase Reply with quote  Mark this post and the followings unread
im using cubase sx 3
im fairly new to cubase, i have recorded a midi loop to an audio track, i want to export this audio so i can edit it in sound forge, when i export it, it saves as an OMF file.
i cant open this in sound forge, i was wondering how can i export as a wav file? any help is appreciated
make
PostPosted: Sun Aug 27, 2006 8:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
select the track you want to export. set up the markers for the section you want. select 'file > export > audio mixdown' and then make sure you select the right settings in the save applet that pops up.
You'll have options for the following:
Channels: mono/stereo/stereo interleaved
Outputs: Master stereo out/FX channels/VST instruments
Resolution: 8/16/24/32/32(float) bit
sample rate.
then option to import into audio pool
if you import it into the audio pool then it will appear in project folder/audio as a wav file you can then open in sound forge.
Hope this helps.
larns
PostPosted: Mon Aug 28, 2006 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for that
