  Paulo Santos Synth-ing NºX
request: casio mt-800 service manual
mi_dach
PostPosted: Mon Jul 17, 2006 9:56 am    Post subject: request: casio mt-800 service manual Reply with quote  Mark this post and the followings unread
just wondering if anyone has some internal details on the mt-800.. thanks
fabreeze
PostPosted: Fri Jun 17, 2011 8:46 pm    Post subject: casio mt-800 internals
Subject description: mt-800 analog drum section
I know your post is old but I just opened up an mt-800 and poked around. It has really nice analog drum sounds. Most of the drum circuits are encased in resin or something with many leads going into the pcb. There are 5 trim pots that change the decay of the drums and some will oscillate if turned up all the way. Unfortunately, the bassdrum does not, but it still has oompf!! There are a handful of resistors in a row that are all connected on one side forming a mixer before going into an opamp. There is silkscreen labels next to each resistor to tell what sound it is. The drum part of the snare and the noise part are mixed in separately. There are some rounded globs of solder near this area that are the trigger inputs for the individual drums. The snare and hihat don't really make any sound unless the rhythm generator is started and running. This is because the metallic cymbal/hihat sound and the white noise are both generated digitally by the surface mount microcontroller that is on the solder side of the pcb. They were the 2nd and 3rd pin down on the right side of the chip respectively. All in all, it would not be difficult to add volume controls for each drum sound, individual output jacks, trigger input jacks, decay knobs, and outputs for the metallic noise and white noise. I hope this helps someone!!
CYBERYOGI =CO=Windler
PostPosted: Sun Aug 05, 2012 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
A single dead drum sounds like a bad electrolytic capacitor. When they leak/ vapour out, they loose capacitance/increase resistance and so shorten the drum decay envelope until it disappears.
Also check for an accidentally misadjusted or dirty percussion envelope trimmer. (Mark previous positions with a felt pen before you adjust them.)
MAY THE SOFTWARE BE WITH YOU!
CYBERYOGI Christian Oliver(=CO=) Windler
(teachmaster of LOGOLOGIE - the first cyberage-religion!)
*=============================ABANDON=THE=BRUTALITY==========================*
{http://weltenschule.de/e_index.html}
