Wogglebug circuit
Page 1 of 14 [332 Posts]
Goto page: 1, 2, 3, ..., 12, 13, 14 Next
EraSer
PostPosted: Tue Oct 24, 2006 12:21 am    Post subject: Wogglebug circuit Reply with quote  Mark this post and the followings unread
I've seen and heard this random and crazy voltage generator #3 Standard WoggleBug Twisted Evil .I've put it in my DIY list. study
Before I need some info about it: first of all, does it run with 9V battery?
It has differents outputs:each output give a different sound Question
Is there a PCB layout?
synth_ollie
PostPosted: Tue Oct 24, 2006 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.modularsynth.net/topic-221.html
EraSer
PostPosted: Tue Oct 24, 2006 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you synth_ollie for informations. Wink
a curiosity:could I run it with 9v?
bugbrand
PostPosted: Tue Oct 24, 2006 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Synth_Ollie --- you star! I've been wanting to do one of these for ages (hmm, actually, better not launch straight into making one 'cos I shouldn't let myself get sidetracked from other work...)
9v supply -- it probably *could* run off two 9v batteries -- maybe check the datasheet of the LM398 'cos that may not be happy at +/- 9v - everything else should work pretty much fine with a bipolar 9v supply..
http://www.bugbrand.co.uk
EraSer
PostPosted: Tue Oct 24, 2006 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I've found datasheet LF398monolitich S&H circuit (are you sure about LM398? Rolling Eyes ).It can operate from +/- 5V to +/- 18 supplies.So do you think I could use tranquilly +/- 9V?
fluxmonkey
PostPosted: Tue Oct 24, 2006 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I FINALLY got mine (a dual) working last night. had a number of errors on the PCB, which i traced out and patched one by one... still no joy, poked at it all weekend and finally found out that the neg. power line on my bench supply had wiggled loose at the source. duh. now, much fun.
there are 3 CVs out plus 3 tones, all different (step, smoothed, and woggled CV; step and woggle tone, "ring" tone). the patch i wound up with last night used one of the tone outs mixed w/ an external VCO driven by one of the CVs... vulcan harmony.
i'll try it out on +/- 9v tonight, but i'm not sure it'll run unmodified... what's the current draw for the vactrols?
bbob
vtl5c3
PostPosted: Tue Oct 24, 2006 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a PCB layout here:
http://web.pdx.edu/~rfahl/img/Wog/
I've built a couple of them. The wogglebug is a cornucopia of strangeness. By that I mean good strange.
mono-poly
PostPosted: Fri Dec 15, 2006 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok i made a modcan panel layout.
It needs a double size panel from cydustries.
Unfortunely there is a little space left.
But it won't fit good in a single one.
Can someone make some beter scalings a la modcan?
 Filesize:  30 KB
 Viewed:  36528 Time(s)
 Filesize:  30 KB
 Viewed:  36366 Time(s)
WIARD WOGGLEBUG.fpd.zip
 Filename:  WIARD WOGGLEBUG.fpd.zip
 Filesize:  2.48 KB
 Downloaded:  1041 Time(s)
PostPosted: Fri Dec 15, 2006 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like this?
btw- these go to 11!! Laughing Doing the text without knowing what font Modcan use is like looking for a needle........
It's a rush job, but you get the idea?
 Filesize:  23.46 KB
 Viewed:  36329 Time(s)
ACHTUNG!
mono-poly
PostPosted: Fri Dec 15, 2006 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah that looks pretty neat.
But i think the lines and the numbers need to be a big thicker.
Because when i use them on a panel they are scaled down and can't be read that easy.
mono-poly
PostPosted: Fri Dec 15, 2006 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lol till 11 you need to start at 0 Smile
Here is an example
PostPosted: Fri Dec 15, 2006 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
These examples aren't actual photographs, they've been done in an illustration application. I can't get an exact replica without seeing an actual front panel, but I can supply you with a dxf. You can get a dxf viewer on the net.
ACHTUNG!
PostPosted: Fri Dec 15, 2006 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
That isn't entirely true. Remember we are dealing with technical information here, not illustration info.
how about this;
 Filesize:  18.56 KB
 Viewed:  36292 Time(s)
ACHTUNG!
PostPosted: Fri Dec 15, 2006 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
the inside hole is exactly M8- the width for a standard potentiometer
ACHTUNG!
mono-poly
PostPosted: Fri Dec 15, 2006 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you make the outer circle also thick?
And please put it on the forum as hpgl?
Maybe also the first one with thinner lines.
I got the graveyard shift now but then i can check out tomorow of it looks better in my schaeffer designs.
Thanks !
PostPosted: Fri Dec 15, 2006 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
An HPGL file is a file system used by Hewlett Packard for plotters.
I don't have the means to support hpgl.
Sorry.
ACHTUNG!
PostPosted: Fri Dec 15, 2006 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
What ? Modern CAD software can't do plotter output anymore Shocked
PostPosted: Fri Dec 15, 2006 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
DXF only AFAIK.
AutoCAD still plots but not hpgl.
If anyone knows any different please tell us Smile
ACHTUNG!
PostPosted: Fri Dec 15, 2006 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you do Gerber output ? It seems easier to find gerber to hpgl than autocad to hpgl freeware. Or is gerber for pcb's only ?
PostPosted: Fri Dec 15, 2006 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm gerber, possibly- but not from AutoCAD. Perhaps an older version of autocad would do it? R12? dunno
a gerber file is very similar. I think the best thing to do would be to contact Schaffer. The other thing is the line thickness. I think that dxf is fine for knowing where exactly to put the holes in, but you would still have to rely on transfers for the artwork. Schaffer shallow drills into the surface of the metal. crude but it looks good- especially when the surface is painted Smile
ACHTUNG!
mono-poly
PostPosted: Fri Dec 15, 2006 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
A bmp is fine to.
I got a tool to convert it to hpgl.
I need hpgl to import graphics in the software from schaeffer.
PostPosted: Sat Dec 16, 2006 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
mono-poly wrote:
A bmp is fine to.
hoorah!
resolution? what resolution do you need??
ACHTUNG!
mono-poly
PostPosted: Sat Dec 16, 2006 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the bigger, the better.
I can scale it down in the software from Schaeffer.
PostPosted: Sat Dec 16, 2006 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
To come back on the hpgl item, even when its not any good anymore, but for completeness, I found :
You should be able to 'print to file' and that should be a PLT file.
In Acad, start the plot command, and on the first screen ( of teh two: plot settings ) there shoudl be a 'plot to file' button in the loser right corner. Click that, and the plot file will be exportetd out as a .PLT file.. then choose your 'printing area and scale' and click OK..
here.
ickystay
PostPosted: Wed Feb 21, 2007 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I've etched and populated a board for one of these. The pots on the schematic don't have their names. Can someone help please? Thanks.
