Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Wed Feb 05, 2003 11:00 am Post subject:
MP3 file included in posts |
I've been working on making it possible to put MP3s in posts. I'm including a very short one in this post. I need feedback. I'm not sure how this will work for people who are on dialup connections. This file is coded at 128 mbs. It works fine on my cable modem connection. My hope is that it will automatically get buffered for people with slower links. If not, we may have to download stuff encoded as much lower bit rates.
The mp3 and other audio compressed files are configured to use the windows media plugin. According to the documentation, they have plugins for all of the sytems, including Linux and MacIntosh. If you don't have the plugin loaded, the software should get it automatically.
Here are two files for testing.
Please let me know how this is working for you. You can just post a reply to this topic.
Thanks...
| Description: |
| This is a sample file. I like it a lot. I forget where the file came from. Some great site as I recall |
 Download |
| Filename: |
fhqwhgads.mp3 |
| Filesize: |
1.59 MB |
| Downloaded: |
821 Time(s) |
| Description: |
| Here's a nice MIDI file to test the midi download. I'm not sure what it is. I believe it's Nuno Cage. |
 Download |
| Filename: |
southd_1.mid |
| Filesize: |
48.85 KB |
| Downloaded: |
211 Time(s) |
rmiller
Joined: Feb 03, 2003 Posts: 39 Location: Bethlehem PA 18018 USA
Posted: Wed Feb 05, 2003 11:46 am Post subject:
Streaming audio |
Just in case this behavior isn't what you intended, clicking on the link in the e-mail started 1st .mp3, which when ended, 2nd file started automatically (while the status bar in 1st also began again as tho looping). Perhaps starting each cut should be left to the listener? _________________ Robin Miller |
egw
Joined: Feb 01, 2003 Posts: 1502 Location: Asheville NC
G2 patch files: 8
Posted: Wed Feb 05, 2003 11:49 am Post subject:
| It crashed my browser (Netscape 4.7). |
Audio files: 107
Posted: Wed Feb 05, 2003 11:54 am Post subject:
Rlobin,
Thanks for the prompt reply. Try it now... I changed a parameter... _________________ --Howard
my music and other stuff |
Audio files: 107
Posted: Wed Feb 05, 2003 2:44 pm Post subject:
OK, I took out the streaming feature and just do downloads. Too bad that people will be running obsolete browsers. If anyone finds any problems with the mp3s, please let me know. _________________ --Howard
sundagger
Posted: Wed Feb 05, 2003 7:32 pm Post subject:
Both songs played just fine under Chimera 0.6, Max OSX 10.2.3. _________________ Brian Good
Broken Symmetry | An electro-acoustic free improv collective |
Audio files: 107
Posted: Wed Feb 05, 2003 7:49 pm Post subject:
Well, Brian, thank you very much.
OSX, better than what I'm using, Windows ME
Would you try to upload a mp3 file? If you would rather use some other format of compressed audio, I'll try and configure the server to accept it. I think the configuration will also accept RealAudio files with a .rm extension.
Thanks again... _________________ --Howard
djfoxyfox
Joined: Feb 05, 2003 Posts: 760 Location: Nazareth, Pennsylvania, USA
Posted: Wed Feb 05, 2003 9:40 pm Post subject:
Nothing played and nothing downloaded. I was provided with a table having stats about the two files and offered the chance to download these files.
Sundagger? That must mean Brian's here. Cool! _________________ Bill Fox------------------|\--------------
--|_)| -----|-----()----------------------
-----------()----soundscapes.us/bill |
Audio files: 107
Posted: Wed Feb 05, 2003 9:46 pm Post subject:
nothing played |
Bill,
Sorry it didn't work for you
What version of what browser are you using? What OS? Did you wait a very long time? I know you're on a dialup. Can you watch your modem lights to see if data is coming down the pipe? _________________ --Howard
jack
Joined: Feb 06, 2003 Posts: 21 Location: East Coast USA
Posted: Thu Feb 06, 2003 7:08 pm Post subject:
Streaming |
Mp3 cool but streaming would be great. _________________ JACK |
Posted: Wed Apr 23, 2003 5:17 pm Post subject:
Hmm.. I tested both files. Works fine. Perhaps you should put in a target=blank so the file opens in another browser window.
Works fine on OSX 10.2.5 with IE 5.2, Chimera and Safari.
By the way.. I would love to hear more of both those tracks.
I guess download is the best choice. Or is there a way to do BOTH? And /or possible choose options when uploading? And perhaps there should be some sort of way to attach a copyright notice or whatever to a file? I do not know this forum but I guess it is possible to add that feature in. |
e-sin
Joined: Apr 29, 2003 Posts: 8 Location: statesboro, ga
Posted: Wed Apr 30, 2003 2:36 am Post subject:
both links bring up download dialogs in opera 7.1...pasting the locations into winamp 2.9 start streams, but on my 56k, there are of course gaps as it has to rebuffer (expected).
what sort of server is this site run from? i don't know a whole lot about php but...from what i do know, i would think that it would be pretty simple to have a script execute upon upload completion that could re-encode the mp3 at a lower bitrate for streaming and link to a .m3u refrencing to the file.
alternatively, you could leave it up to the user to tell the server what to do by letting it know what sort of file it was...for example, four checkboxes corresponding to download (link to mp3), stream (link to generated m3u), and then stream quality (low, high) could do the trick...probably easiest solution. autodetection of the bitrate might be worth looking into as well.
with re-encoding uploaded mp3s into dialup suited streams...might not be much of a problem yet, but at some point, that's going to make your server wish you were dead. you could impose a 5 (or whatever) upload per user per month limit, or a certain number per day that was applied site wide, served out on a first come, first serve basis to try and make sure that the server doesnt get too stressed.
just a few ideas i had...:) _________________ ~josh/e-sin
www.emmrecords.com/e-sin |
Audio files: 107
Posted: Wed Apr 30, 2003 10:47 am Post subject:
| e-sin wrote: | | both links bring up download dialogs in opera 7.1...pasting the locations into winamp 2.9 start streams, but on my 56k, there are of course gaps as it has to rebuffer (expected). | Doesn't that mean you could have chosen to download the files and listened after everything came down? | e-sin wrote: | | what sort of server is this site run from? i don't know a whole lot about php but...from what i do know, i would think that it would be pretty simple to have a script execute upon upload completion that could re-encode the mp3 at a lower bitrate for streaming and link to a .m3u refrencing to the file. | The server is a 450 MHz Linux system with a 1 Mb symetrically DSL. I'm not keep on re-encoding on the fly with such minimal hardware. | e-sin wrote: | | alternatively, you could leave it up to the user to tell the server what to do by letting it know what sort of file it was...for example, four checkboxes corresponding to download (link to mp3), stream (link to generated m3u), and then stream quality (low, high) could do the trick...probably easiest solution. autodetection of the bitrate might be worth looking into as well. | Yes, that is the easiest, and best solution I think as well. I don't know how to do autodetection of bitrate. | e-sin wrote: | just a few ideas i had... | Thanks, for the thoughts. _________________ --Howard
e-sin
Posted: Wed Apr 30, 2003 11:38 am Post subject:
yes, i could have done so, and did with the smaller of the two.
i have no idea if this would help you on the autodetection thing or not, but figured i'd give it to you anyway, in case you were interested in it, even if not for the site.
http://www.yolinux.com/TUTORIALS/LinuxTutorialAudioStreaming.html
i wouldn't want to do that reencoding thing either...sure would be cool though! _________________ ~josh/e-sin
metricks
